I just recently starting getting sporadic false alarms that the battery is at 0%. It has occurred both plugged in and not plugged in, and at various states of charge. A few seconds later, the real battery status reappears. It is somewhat annoying because it dims the screen, plays a sad sound and threatens to sleep the computer in 60 seconds.
Any ideas?
Thanks
Which Linux distro are you using? Bazzite
Which release version? 44
(If rolling release, last date updated?) Moments ago
Which kernel are you using? 7.1.5-ogc5.1.fc44.x86_64 (64-bit)
Which BIOS version are you using? 04.02
Which Framework Laptop 13 model are you using? (AMD Ryzen™ AI 300 Series, AMD Ryzen™ 7040 Series, Intel® Core™ Ultra Series 1, 13th Gen Intel® Core™ , 12th Gen Intel® Core™, 11th Gen Intel® Core™) 300 Series HX370
