Steam Controller Puck Issues with Framework 13 Pro, Core Ultra X7 358H
I’m using CachyOS with Kernel 7.2.9-1 on a Framework 13 Pro, Core Ultra X7 358H. Last updated today. fwupdmgr says I’m using firmware 0.0.3.2.
This is working quite nicely except I can’t seem to get the Steam Controller Puck to come up when connected to any hub connected to the laptop. It doesn’t matter which hub I use. The puck worked fine on these hubs on my previous AMD board on Ubuntu 26.04.
Every other device seems to work fine on these hubs but my research suggests that the puck is special as it’s trying to setup USB 2.0 for many devices at once (4 possible controllers), overwhelming the, what seems to be, single transaction translator reported for the port on the Framework.
I’m curious if anyone has any deeper experience with this than I do. Is this how these ports are supposed to work for older USB specs on this mainboard or am I having a kernel issue?
When connecting through any hub:
Oct 06 23:17:25 Framework kernel: usb 3-2.2: new full-speed USB device number 115 using xhci_hcd
Oct 06 23:17:25 Framework kernel: usb 3-2.2: New USB device found, idVendor=28de, idProduct=1304, bcdDevice= 0.02
Oct 06 23:17:25 Framework kernel: usb 3-2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Oct 06 23:17:25 Framework kernel: usb 3-2.2: Product: Steam Controller Puck
Oct 06 23:17:25 Framework kernel: usb 3-2.2: Manufacturer: Valve Software
Oct 06 23:17:25 Framework kernel: usb 3-2.2: SerialNumber: FXB9960101130
Oct 06 23:17:25 Framework kernel: usb 3-2.2: Not enough bandwidth for new device state.
Oct 06 23:17:25 Framework kernel: usb 3-2.2: can't set config #1, error -28
When connecting directly:
Oct 06 23:15:19 Framework kernel: usb 3-3: new full-speed USB device number 110 using xhci_hcd
Oct 06 23:15:20 Framework kernel: usb 3-3: New USB device found, idVendor=28de, idProduct=1304, bcdDevice= 0.02
Oct 06 23:15:20 Framework kernel: usb 3-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Oct 06 23:15:20 Framework kernel: usb 3-3: Product: Steam Controller Puck
Oct 06 23:15:20 Framework kernel: usb 3-3: Manufacturer: Valve Software
Oct 06 23:15:20 Framework kernel: usb 3-3: SerialNumber: FXB9960101130
Oct 06 23:15:20 Framework kernel: cdc_acm 3-3:1.0: ttyACM0: USB ACM device
Oct 06 23:15:20 Framework kernel: input: Valve Software Steam Controller Puck Mouse as /devices/pci0000:00/0000:00:14.0/usb3/3-3/3-3:1.2/0003:28DE:1304.005E/input/input173
Oct 06 23:15:20 Framework kernel: input: Valve Software Steam Controller Puck Keyboard as /devices/pci0000:00/0000:00:14.0/usb3/3-3/3-3:1.2/0003:28DE:1304.005E/input/input174
Oct 06 23:15:20 Framework kernel: hid-generic 0003:28DE:1304.005E: input,hiddev103,hidraw14: USB HID v1.11 Mouse [Valve Software Steam Controller Puck] on usb-0000:00:14.0-3/input2
Oct 06 23:15:20 Framework kernel: input: Valve Software Steam Controller Puck Mouse as /devices/pci0000:00/0000:00:14.0/usb3/3-3/3-3:1.3/0003:28DE:1304.005F/input/input176
Oct 06 23:15:20 Framework kernel: input: Valve Software Steam Controller Puck Keyboard as /devices/pci0000:00/0000:00:14.0/usb3/3-3/3-3:1.3/0003:28DE:1304.005F/input/input177
Oct 06 23:15:20 Framework kernel: hid-generic 0003:28DE:1304.005F: input,hiddev104,hidraw15: USB HID v1.11 Mouse [Valve Software Steam Controller Puck] on usb-0000:00:14.0-3/input3
Oct 06 23:15:20 Framework kernel: input: Valve Software Steam Controller Puck Mouse as /devices/pci0000:00/0000:00:14.0/usb3/3-3/3-3:1.4/0003:28DE:1304.0060/input/input179
Oct 06 23:15:20 Framework kernel: input: Valve Software Steam Controller Puck Keyboard as /devices/pci0000:00/0000:00:14.0/usb3/3-3/3-3:1.4/0003:28DE:1304.0060/input/input180
Oct 06 23:15:20 Framework kernel: hid-generic 0003:28DE:1304.0060: input,hiddev105,hidraw20: USB HID v1.11 Mouse [Valve Software Steam Controller Puck] on usb-0000:00:14.0-3/input4
Oct 06 23:15:20 Framework kernel: input: Valve Software Steam Controller Puck Mouse as /devices/pci0000:00/0000:00:14.0/usb3/3-3/3-3:1.5/0003:28DE:1304.0061/input/input182
Oct 06 23:15:20 Framework kernel: input: Valve Software Steam Controller Puck Keyboard as /devices/pci0000:00/0000:00:14.0/usb3/3-3/3-3:1.5/0003:28DE:1304.0061/input/input183
Oct 06 23:15:20 Framework kernel: hid-generic 0003:28DE:1304.0061: input,hiddev106,hidraw21: USB HID v1.11 Mouse [Valve Software Steam Controller Puck] on usb-0000:00:14.0-3/input5
Oct 06 23:15:20 Framework kernel: hid-generic 0003:28DE:1304.0062: hiddev107,hidraw22: USB HID v1.11 Device [Valve Software Steam Controller Puck] on usb-0000:00:14.0-3/input6
It tells you right there in the logs. The hub is not allowing enough bandwidth to the puck.
Yes, I get that, but this happens with every hub I try, including hubs that seem to identify as capable. This did not, however, happen with the Ryzen board I had in the previous Framework with all the same hubs.
My fw16 gets wonky with my dock as well. Sometimes I have to shut down the laptop and let it sit for a few minutes, then power it back on with the dock NOT connected. Once it’s up, then connect the dock and all is well. Give that a try.
