Which release version?
10/16/2026
Which kernel are you using?
7.2.10-1-cachyos
4.01
Which Framework Laptop 16 model are you using? (AMD Ryzen™ 7040 Series)
AMD Ryzen 7040
I recently received my Steam Frame VR headset. On my Framework 16 running cachyos, I will plug in the USB receiver which will be functional for a session. After the computer sleeps, restarts, or the receiver is unplugged and plugged back in, the computer goes through a few minutes of trying to configure the adapter. Eventually it stops being recognized by the computer. The port works with other devices, but when the receiver is plugged in, no USB events are triggered and it does not show up in USB devices. The only way I’ve found to fix it is by disconnecting the battery in the bios. Anyone have any clue how to fix this?
This is a longstanding bug in Framework’s firmware for the ports. It’s frustrating that they aren’t fixing it. It is a common issue with usb drives as well. If you plug and unplug them 3 times they completely stop working in that port until you power down and power back on. The only workarounds I am aware of is to either move it to another port which will work for 3 more plugins, or power off and on the laptop again.
Until Framework decides to fix this bug, if ever at this point, i think this is all we can do.
This explains so much of the confusion I’ve had around drive behavior. If I had to pick one problem that has been most frustrating with the Framework 16: it’d be the usb port management. Between the power delivery issues, overcurrent tripping issues, battery flipping issues, power de-rating issues, and etc. the main thing that would get me to upgrade my Batch 1 motherboard would be an overhaul improvement of the usb and power delivery system.
Thanks for the feedback everyone. This context led me to a GitHub issue which suggested disabling auto suspend on the USB hub. I have just tried that and unplugged/plugged a few times with no issue. I will try it out for a few days and report back
Reporting back- that did not work at all. It’s interesting because I can unplug and plug in the receiver all I want, but the second I make the connection once, it’s game over. This is shockingly unacceptable and more shocking that it hasn’t been addressed yet. USB should just work
I’ve had issues more issues with the ports closest to the user (3 & 6) than any other. I’m assuming you’ve tried the other more full-featured ports? Perhaps the same port Valve is demonstrating in that link? I don’t have my FW16 in front of me, so idk which port that is. Hopefully it’s not #3, cause that would be awkward.
Yeah you don’t see anything in dmesg once the port goes “disabled”. On the frame dongle side, I haven’t been using it anyway because it is still really unstable on Linux. The led finaly lights up on kernel 7.3 though, so I assume some work is being done to get it better supported on Linux. I have a ubiquiti U7 pro in my house that already works well so I don’t really need to use the dongle for streaming anyway.
This is interesting- I have not had the same experience on WiFi only with a similar setup. The only difference is I am using a u7 lite. I have direct line of sight, and it works very well most of the time, but every several minutes, I experience a few seconds of horrible connection quality, like 3 frames per second bad, which makes it really bad for things like beat saber. Do you have a workaround for this or was this a non-issue for you?
