Ubuntu 24.04
Which release version?
Which kernel are you using?
Which Framework Laptop 16 model are you using? (AMD Ryzen™ 7040 Series)
AMD Ryzen AI 300
I am using what I think is the secondary drive (smaller footprint under the larger M2.220) for the OS, and the primary M2.220 drive as my /home mount point. I transferred the M2.220 drive with /home from my old laptop.
Just curious if there is enough thermal pad area for the top drive. I see a small thin grey thermal pad attached to the mid-plate. I am used to larger thermal pads (see the blue thermal pad in the photo). Should I replace the grey one or use both?
Thanks,
Mark
