Hi Everyone,
So very weird problem i have here. It looks like a few ants found their way inside the Framework case, and caused a short circuit and the desktop won’t start now. I’m trying to do some tests before giving it to a technician, to make sure whether the issue is with the PSU or the motherboard (please god no
). How can i troubleshoot this, i read somethere i could on the 24-pin ATX connector, insert a metal paperclip to bridge Pin 16 (PS_ON - usually green wire) and any Ground pin (black wire, such as Pin 15 or 17), and see if the PSU fans starts, and based on that I can check whether its a PSU or motherboard issue.
I don’t have another powersupply around or multimete unfortunately as well.
