When I first got my Framework 13 (AMD 7840u), it came with some stock thermal paste. I switched to Honeywell’s PTM 7950 about a year ago, just like the new ones ship from HQ.
I recently got some Geektc GX-300, a rather new graphene based thermal interface which should outperform past graphene sheets by a mile and got great reviews by Igor’s Lab (also available as German video and article).
So I decided to replace my PTM, but before that checked how well it still performed:I locked fan speeds at 100%, ran Blender Classroom benchmark (via phoronix-test-suite) multiple times (heat soaking) and then only counted the last three averaged runs:
| PTM 7950 | GX-300 | Improvement | |
| Time to Complete | 402.60s | 360.93s | -10.4% |
| CPU t avg | 86℃ | 80℃ | -7.0% |
| CPU t max | 93℃ | 88℃ | -5.4% |
| CPU Clock avg | 3421MHz | 3653Mhz | +6.8% |
| CPU Clock max | 4861MHz | 4903MHz | +0.9% |
So overall, I am very satisfied with the performance and I can recommend it if anyone wants to squeeze out that tiny bit of extra performance or quieter laptop for the same performance…
As for applying it:
Cleaning the PTM was tough, as it got squished between the small SMDs around the chip. couldnt fully clean the SMDs, but at least the chip was clean.
For the graphene sheet: it is conductive, so i had to protect the surrounding SMDs from shorting out as the sheet is larger (and not trimmable) than the actual die. The GX-300 came with some isolating stiff sheet which I cut in shape and applied to the surrounding components, leaving a hole for the cpu die. This was the most difficult part already, as applying the thermal interface was super easy:
Remove the first protective film of the graphene sheet, place it on the die and take away the transfer protective sheet. Done. Now just reassemble and enjoy your new cooling solution.
