Third Party Display Upgrade
Hey all,
Looking at buying an FW12 for use in my work as an audio engineer, but am interested in doing some photo editing, pixel art and drawing outside of that.
Seems a common sticking point here is the pretty underwhelming display the FW12 comes with by default, and was wondering if anyone here knew of any third-party touch displays compatible with the 12 that are a bit more vibrant? Either that or a hint at what sort of Googling I need to do to hunt one down myself would be super helpful, and inform my decision to purchase or not.
Thanks!
Does it need to be portable? There are a bunch of USB-C external LCD displays, and they generally just run from the power of the USB system itself. However, it is not a replacement for the internal screen - it props up alongside the FW12.
Yea I’d want it to replace the internal screen of the laptop, the appeal of the FW12 for this workload is the convertible, ultra-portable nature of it.
Your best bet is here in the forums where people come up with a multitude of mods. Sadly there seems to be no practical solution for a better display yet. People with expert knowledge and access to all kinds of vendors have tried finding something, without much success.
Framework does not share info on future products until they can be at least pre-ordered. So the closest thing that gives some hope is that they acknowledged that it came up as strong request in user feedback surveys and that they are looking into it. Don’t remember the exact phrasing, but it stood out compared to their usual communication. Sadly no timeframe, but I think an official upgrade at some point in the future is our best chance currently.
So in a nutshell: Googling will not bring up anything useful. It’s really a leap of faith at this point - if a better display in the future is important to you.
Personally it was an easy choice. There is just nothing comparable on the market for me, even with the weak color accuracy (which does not bother me in everyday media consumption and mostly office work). Also pretty confident Frameworks have a good resale value if I decide to switch to something different. Currently own a 1st gen FW12 and pre-ordered the new generation. Full laptop, because I think selling the 1st gen is easier as a whole. But even more likely it will stay with a family member.
