Thoughts on carry bag for Framework Desktop
Hi All,
I love my Framework Desktop and carry it back and forth between home and office quite a bit. I think it’s reasonably robust, but I’ve been using a camera bag to protect it in my backpack. The camera bag is a Neewer NB-PT. It’s slightly larger than the Desktop+handle and does an ok job - you can make the fit tighter using the velcro padded dividers that come with the bag (designed for an SLR plus lenses, so pretty configurable). I was wondering if anyone has thoughts on an alternative, or has any opinions about the matter in general?
I use this thing. The plan was to carry they DESKTOP + small BT keyboard + a portable screen and a mouse in that case.. and it fits, but a 17inch screen I bought to use with the desktop does not fit, So I either use a thinner 14inch or plug it to a 27inch screen I have at the office and use the 17inch at home.
I think your camera bag solution is basically a better idea, but I’m often traveling with a camera bag full of cameras, so no room the the Desktop.. So I needed something to go on the shoulder.
Talk about ‘back to the future’
In the day I had a Compaq that I used for ethernet protocol ‘sniffing’ that WAS a suitcase
That’s the most beautiful thing I have ever seen!
It had two full size slots which was perfect for the ethernet protocol analyser capture card
You probably needed gorilla arms to lug it around though.
Brings back my days as a computer tech with a toolcase that I wouldn’t even try and lug around these days.
The best bit of Ethernet analyser software I came across was from Novell, back in the days when having a Novell server was a ‘big thing’. Could use any Ethernet card that could be put into promiscuous mode IIRC.
True. And, when you consider the “mobile” phone of the same period … who needed a gym membership!
And, yes to the Novell days. And, to token ring, os/2, 3com 3plus servers, and all the other crazy tech of the day
Changed my mind about the camera bag. It’s 16cm thick, when only ~10cm are required, so was taking up a lot of extra volume then stuffed into my backpack. Instead, I found a plastic food storage box (the kind with clip on lid - a clip each side) that’s approx 30x21x11cm, and lined it with some padding (6mm neoprene with adhesive backing). Really nice - fits the FW desktop, with handle, perfectly. Now it’s in a waterproof hardshell protective case with no rattling that only takes up about 6.5 litres (the label on box says 6.3), total weight about 3.5-3.6kg.
For the people who take the desktop on the go, back and forth - how often do you do this, and how delicately do you obsess when you transport it ? I’m feeling a little insecure about the prospect of transporting a desktop as opposed to a laptop where everything is (well, in theory) a little more clamped down/unlikely to shake apart during a daily commute
Twice a week, sometimes more. My commute involves 20 minutes of walking and 20 minutes on a bus, so the desktop goes in a backpack (in the aforementioned box, plus neoprene padding, so it’s snug and pretty well protected against impact and shaking). Hard to say how vulnerable this desktop is versus a laptop - I think the biggest difference is the large heatsink maybe putting pressure on the motherboard and potentially stressing tracks or solder joints. I reckon if I was just walking out of the house, hopping in a car, then walking into an office I wouldn’t have made an effort with a case etc. But, one of the reasons I went with the Framework desktop rather than another small desktop was I know I can get replacement parts very easily (I also needed the compute cores and the thermal design).
I just got this bag and the framework desktop fits perfectly, with enough room for a thinkpad x1 nano
