I’ve seen a couple of topics closed after 2 days when no replies are added… surely that is far too short a time, since even just getting through support’s debugging steps can a lot of the time take longer than 2 days.
It used to be 6 months, which I would feel is about right for a ballpark of “no one cares about this issue enough to keep it open for people who find it in a search result or something and have something to say.” Anything shorter than 1 month is nutty.
(I’m also unable to post this without picking 2 tags, so I picked “amd-ai-300” since that was the topic of one of the closed-after-2-days threads.)
It still is 6 months after last reply. The only reason a topic should be closing prior is if Discourse thinks it’s spam, a mod closes it, or a user closes it. If you see it happen again, feel free to ping me and I’ll check it out.
Sounds good - I’ll tag you from a couple that I saw were closed after 2 days. Maybe was some short-lived configuration or something specific to just those threads.
Looks like maybe if it’s marked “solved” then it closes after 2 days? That still seems not ideal; what if someone else has the same problem or the same user has further issues after thinking it was solved or something?
If a topic is marked ‘solved’ then it’ll close a few days after. They’re still searchable and readable, but just won’t show up as active / revolving or comment ready.
