Issue background
So to preface I have been encountering this issue since I first got my framework laptop back in October but I finally seem to have narrowed down the cause (but not a fix). There is an issue where touchpad input causes seemingly abnormal amount of interrupts. This ends up causing extremely high number of context switches and atomic work creating high power usage no matter the CPU usage or performance settings (excerpt from powertop included below). It occurs in TTY, Wayland, and X11. I included all my observations but I am not entirely sure of the context around the data and how to fix.
I am running NixOS on kernel 5.15.2
but this issue has been around since I started with Framework at 5.12.5
. I have never experienced it working. There are a few issues I have found that are seemingly related:
Interrupt benchmarks on X11
Moving the cursor causes extraordinarily high power usage as a result of interrupts. Only the terminal was open for these. As I continue to move the cursor, power usage continues to increase. Excerpt from dstat history showing total interrupts (int), context switches (csw), and specific interrupts (30, 186, 188) in single second intervals. When touching the touchpad it produces ~3000 interrupts/second, and drops to zero is when mouse isn’t moving. Note: the keyboard seems to be correct and produces exactly two interrupts per key press (so around 5-20 interrupts per second).
----system---- ---system-- ----interrupts---
time | int csw | 30 186 188
12-01 02:24:00|4291 4948 | 699 376 45
12-01 02:24:01|1529 761 | 0 26 0
12-01 02:24:02|1381 696 | 0 20 0
12-01 02:24:03|4120 2941 |1298 229 60
12-01 02:24:04|9776 11k|3111 616 142
12-01 02:24:05| 11k 14k|2481 799 127
12-01 02:24:06| 12k 18k|2679 1040 142
12-01 02:24:07| 11k 14k|2735 949 142
12-01 02:24:08| 12k 18k|3112 1054 142
12-01 02:24:09| 11k 15k|2871 1030 142
12-01 02:24:10|9865 12k|3067 899 142
12-01 02:24:11|8589 8820 |3064 899 142
12-01 02:24:12|8383 8291 |3065 782 142
12-01 02:24:13|6050 3717 |2540 449 118
12-01 02:24:14|1435 687 | 0 22 0
12-01 02:24:15|1490 801 | 0 22 0
12-01 02:24:16|1329 599 | 0 19 0
12-01 02:24:17|1487 762 | 0 23 0
12-01 02:24:18|1695 1178 | 0 29 0
The detailed excerpt from /proc/interrupts
. Included PIXA as that I believe is the touchpad and it occasionally hits high power usage.
CPU0 CPU1 CPU2 CPU3 CPU4 CPU5 CPU6 CPU7
30: 0 0 2010982 0 0 0 0 0 IR-IO-APIC 30-fasteoi idma64.2, i2c_designware.2
186: 0 0 0 0 1022896 0 0 0 IR-PCI-MSI 32768-edge i915
188: 0 0 0 0 122111 0 0 0 INT34C5:00 3 PIXA3854:00t
Some other less relevant ones, not sure what they mean:
NMI: 0 0 0 0 0 0 0 0 Non-maskable interrupts
LOC: 893261 740162 921499 767780 1388452 695251 670815 687432 Local timer interrupts
SPU: 0 0 0 0 0 0 0 0 Spurious interrupts
PMI: 0 0 0 0 0 0 0 0 Performance monitoring interrupts
IWI: 20585 16309 13147 11025 720474 16316 15925 9071 IRQ work interrupts
RTR: 0 0 0 0 0 0 0 0 APIC ICR read retries
RES: 12691 11043 21085 15608 25167 11877 12430 24970 Rescheduling interrupts
CAL: 188599 139740 122271 141921 94140 108913 115163 108439 Function call interrupts
TLB: 92443 79167 77591 104669 59372 72812 80577 74698 TLB shootdowns
Powertop benchmarks on Wayland (battery power)
Now for the fun powertop. For this I was on wayland. The first benchmark the only thing running was powertop (with a few background services) in a full screen terminal. I have extremely conservative power settings but notice all the top process power users when I am using the touchpad. Powertop isn’t the most accurate but it definitely wouldn’t be that wrong.
The battery reports a discharge rate of 8.90 W
The energy consumed was 202 J
The estimated remaining time is 3 hours, 59 minutes
Summary: 1412.0 wakeups/second, 0.0 GPU ops/seconds, 0.0 VFS ops/sec and 28.9% CPU use
Power est. Usage Events/s Category Description
1.77 W 30.0% Device Display backlight
1.32 W 6.9 ms/s 454.0 Timer tick_sched_timer
782 mW 1.9 pkts/s Device Network interface: wlp170s0 (iwlwifi)
582 mW 3.0 ms/s 199.7 Interrupt [30] idma64.2
354 mW 7.0 ms/s 119.0 Process [PID 1418] [irq/188-PIXA385]
332 mW 142.7 ms/s 50.7 kWork intel_atomic_commit_work
193 mW 35.2 ms/s 51.0 Process [PID 9543] /nix/store/65ihhv3wk5npiccq4y9dapqw1mf70wfb-dwl-jd-0.1/bin/dwl -s /nix/store/d8ba2wsv5ppjgc0l3
189 mW 1.3 ms/s 64.6 Process [PID 1641] /nix/store/cw74cxb9jxssdvf5lqcyjvc2hlr9larj-keybase-5.8.1/bin/keybase service --auto-forked
181 mW 539.2 µs/s 62.4 kWork rps_work
169 mW 561.1 µs/s 58.0 Process [PID 14] [rcu_sched]
148 mW 1.1 ms/s 50.8 kWork intel_atomic_cleanup_work
115 mW 0.9 ms/s 39.4 kWork engine_retire
Here is a powertop when watching a 4K video on firefox (albeit not hardware accelerated).
The battery reports a discharge rate of 16.9 W
The energy consumed was 322 J
The estimated remaining time is 2 hours, 0 minutes
Summary: 1665.1 wakeups/second, 0.0 GPU ops/seconds, 0.0 VFS ops/sec and 302.5% CPU use
3.48 W 2574 ms/s 13.9 kWork intel_atomic_commit_work
3.41 W 1294 pkts/s Device Network interface: wlp170s0 (iwlwifi)
2.61 W 0.0 µs/s 0.00 Process [PID 2087] /nix/store/9658in1mpbz3a7921sqgjfrplrbdbd64-pipewire-0.3.42/bin/pipewire
1.62 W 30.0% Device Display backlight
1.57 W 16.0 ms/s 549.4 Timer tick_sched_timer
323 mW 186.4 ms/s 26.3 Process [PID 10852] /nix/store/32xbijs1iz5hlzvx28mip7ix68dvhcj6-firefox-95.0.2/lib/firefox/firefox -contentproc -
254 mW 682.7 µs/s 90.0 kWork flush_to_ldisc
226 mW 11.6 ms/s 74.7 Process [PID 9874] /nix/store/qq2ik3vsyh3ag998zxl1gcngf07bc619-foot-1.10.3/bin/foot
207 mW 3.8 ms/s 71.9 Process [PID 11195] /nix/store/32xbijs1iz5hlzvx28mip7ix68dvhcj6-firefox-95.0.2/lib/firefox/firefox -contentproc -
162 mW 0.9 ms/s 57.3 kWork rps_work
150 mW 2.3 ms/s 52.1 Interrupt [30] idma64.2
138 mW 4.0 ms/s 47.4 Process [PID 11148] /nix/store/32xbijs1iz5hlzvx28mip7ix68dvhcj6-firefox-95.0.2/lib/firefox/firefox -contentproc -
137 mW 2.4 ms/s 47.6 Process [PID 10645] /nix/store/32xbijs1iz5hlzvx28mip7ix68dvhcj6-firefox-95.0.2/bin/.firefox-wrapped
135 mW 0.8 ms/s 47.7 kWork iwl_pcie_rx_allocator_work
Note on X11 this is way worse (20+ watt power usage) and a USB 2.0 Goodix device appears.
Finishing off with TTY
Same dstat as X11 test on the tty:
12-01 02:58:00|4997 5652 | 792 398 48
12-01 02:58:01| 364 591 | 0 0 0
12-01 02:58:02| 983 655 | 591 0 50
12-01 02:58:03|2706 1252 |1825 0 132
12-01 02:58:04|2221 1000 |1586 0 123
12-01 02:58:05|2226 1061 |1569 0 123
12-01 02:58:06|1076 703 | 651 0 50
12-01 02:58:07| 355 563 | 0 0 0
Exact same issues appear with the touchpad. And the same power issues (albeit this time with around 5-6 watt power usage as there are no graphics). Still too high though.
Now that you have seen all the observations, I am hoping someone with the right knowledge can point me in the direction of a fix! Took me a few months to learn linux well enough to pinpoint the exact issue and know I wasn’t crazy so I am hoping there is a solution.
