I can’t say I’ve experienced the grounding issue, but in the former case fully removing fwupd isn’t necessary in my experience. You only need to disable fwupd-refresh.timer by running systemctl mask fwupd-refresh.timer, which will prevent the hourly device enumeration that causes the failure. The enumeration can instead be done manually with fwupdmgr refresh --force as needed, which I believe framework recommends regardless. I haven’t had any audio issues since doing this over a month ago
Just to confirm: has anyone tried to use the “disconnect battery” option in the BIOS?
I just did that on a whim and it helped with a different, but related problem:
When the laptop was plugged in for charging (port 1) and I unplugged the cable on the power brick’s end and plugged in my phone there, the phone would give a notification saying “liquid or debris in USB port”. Of course the laptop’s port would then become useless until the next power down and restart.
Swapping expansion cards didn’t solve it, so it wasn’t wear on the ports that caused it - same operation on port 4 wouldn’t cause any issues regardless of how I swapped expansion cards.
After the battery disconnect procedure port 1 works normally just like port 4.
I’m mentioning this because whenever it happened with the Audio expansion card plugged on the same side, it would fail, meaning it has to be the PD controller which shuts down.
I’m probably going to do this, but I’m going to hold off until the bug happens again. I may be jinxing myself, but I haven’t seen this bug (or the crazy screen freezes) since upgrading to firmware 4.5 a week or two ago.
FWIW, my audio symptom is/was a little different from what is usually described here (there seems to be some variability in symptoms), so I’m not sure if it’s the same root cause(s) or not.
Fingers crossed…
In my case it’s now just a symptom of the longstanding “USB ports shut down permanently when the device goes to sleep” issue.
That being said today I accidentally found a way to kick the audio card back into life in some cases. Having the headphones plugged in but not giving any sound, just change the output device to speakers, manipulate the volume and change back, manipulate the volume (this time that of the audio card).
It’s really silly that one has to do this, but at least it works.
