I did a lot of testing over the last few days (TLP, auto-cpufreq, PPD, just Kernel) . Summing up i noticed a much higher battery drain of the AMD 7040 compared to my Core i7 (13 gen) but i managed to reduce the power consumption on battery significantly.
First of all beside of firmware problems (wifi needs > 60s to initialize) i noticed that the AMD wifi card uses a lot more energy (+0,5W in Idle and 1-2W under load) than my “old” Intel AX210. I removed the AMD wifi chip and replaced it with the AX210 on my AMD7040 mainboard with no issues so far and the benefit of battery saving.
My test setting was always: 1.)  idle (20% Backlight; no running apps; after 2 mins); 2.) light browsing (Firefox on different websites); 3.) writing a text in Libreoffice; 4.) watching Youtube-Video (1080p; av1).
I’m using Manjaro Gnome with Kernel 6.6.0.
Here are my results:
just Kernel: 1.) 6-7W; 2.) 10-12W; 3.) 8-10W; 4.) 16-20W
PPD (power saver): a little bit worse than just Kernel, so i can’t understand the recommendation of that daemon?
auto-cpufreq alone(standard config): 1.) 5-6W; 2.) 8-11W; 3.) 7-9W 4.) 14-18W
TLP and auto-cpufreq in combination (all CPU optimizations must be commented in TLP!): 1.) 4-5W; 2.) 5-8W; 3.) 5-8W; 4.) 11-15W
I have the best results with TLP and auto-cpufreq in combination. After two days of heavy using my Framework with that setting i experienced no major issues so far. The only thing is a weird behavior after suspend that shows up occasionally. The cpu then tends to throttle under load. A reboot resolves that. One setting in TLP that reduces the power consumption above all was the powersupersave of pcie (ASPM).
As I’m writing this text in Firefox my power consumption is always between 5-6W which is really good…for now I’m satisfied.
