[TRACKING] PPD v TLP for AMD Ryzen 7040
These scenarios:
Testing with Big Buck Bunny 1080p24 H.264 loaded in vlc looped 3X:
With va-api hw accel, 31 mins used 7% battery avg 7.45W draw.
Without hw accel, 31 mins used 7.5% batt at 7.98W avg draw.
Config for testing: ppd balanced, epp balance_power, usb autosuspend, Xfce screen scaling at 0.8, sound muted, brightness at first bar, a few terminals open, browser closed, wifi on & connected, bt off, camera & mic off via hw switches.
I’ve been encouraging observation over 10% or more battery usage for the sake of comparative data. In this case, it looks like the video would need to loop 4-5X.
In my experience, looking at ‘instantaneous’ readings are often misleading (ie: they don’t often/necessarily correlate to actual run times).
Note: after installing mpv, it exhibited some artifacts and stuttering, so I uninstalled it and used vlc, the player I’d previously tested on the FW13.
Conclusions:
  • the differential between hw accel being on/off via Netflix on FF and a local vid are similar
  • mpv may have issues (at least on Ubuntu 22.04.3)
  • as @Michael_Wu notes in his thread linked above to the video file, the Fedora freeworld drivers may have higher power drain
To clarify, my observations are ~1W differential with hw accel on (more efficient) or off (less efficient). Not vs idle usage.
Hi @1115, looking at your other post, the 6.6.4 kernel you indicate using should offer efficient power management.
What steps have you taken to test & tune?
If you’d like some guidance, please see my previous posts above.
At very least, my suggestion is to:
a) ensure amd_pstate is active and set it to balance_power or power
b) if running PPD, set to power-saver or balanced
c) enable usb autosuspend if it isn’t already
It looks like your 6800H has a base TDP of 45W but can draw more than double that!
Hope this helps :upside_down_face:
It’s not quite that bad on my framework, worst case is the 8k 60 youtube video and that maxes out at around 13W
Well you did test at pretty much the point where the curves meet, below that sw decoding wins (not by much but it does), above it sw decoding looses massively.
Also you can use powerstat to get better readings than messing with battery percentages. in my testing I let it settle for a couple minutes then run powerstat for 8 minutes.
10% sounds excessive unless you have some very active background tasks or something. I have found after a couple minutes it settles.
  • Well you did test at the one point where they are relatively equal, retest with 720 and 4k and see a quite different story.
  • Don’t think there is anything specifically wrong with mpv
  • that’s probably more settings than anything else. There are some you can do to make a 1-2w difference in hw decode but it’s still way too much.
Yeah the windows observations are 1W vs not decoding at all. On my old t480s hw decoding a 720p 30 video takes a bit over 2w over idle which is much more reasonable than the 4-5 the much newer phoenix chip seems to use at this point.
My default pstate was performance. Changing pstate to power (echo "power" | sudo tee /sys/devices/system/cpu/cpu*/cpufreq/energy_performance_preference ) drops me down ~0.7W idling. I’m still a far cry from idling at 3W or whatever, but it’s still an improvement.
What is confusing though: why is PPD not making this change for me? I haven’t used linux on a laptop in ~10 years so I’m super out of touch, and the documentation is confusing to me. It reads like it would as a fall back, but because my laptop supports the “platform profile” (whatever that is) it uses that instead. I don’t know what platform profile does, but what it definitely doesn’t do is change pstates.
What is PPD’s thought process here?
There is a pull request that adds it that isn’t yet merged.
Powerstat/powertop are polling on an interval, so they show approximate draw.
It should be more statistically accurate to use a timer and % battery use to calculate avg draw :thinking:
I also let things settle in for a few mins before testing.
Then for whatever change I’m observing (different EPP setting or video draw), my target is 10% battery use or more as that will help smooth out any spikes to provide accurate average draw. Timer starts when the battery drops 1%. Then the timer stops when the battery changes to the target percentage.
This also lends itself well to extrapolating run time for the whole battery to evaluate specific use cases. Such as: how long can I watch a video offline? Could be useful for a long flight. Or in the case of this thread, can I work offsite without an outlet for a whole day?
I’ve tested & shared my results for Netflix and a local HD video which covers my use cases. Feel free to perform further testing & share your results. I encourage the above methodology for the reasons indicated if you’d like comparative data.
Good to know. Based on others observations and my own, it looks like multiple commits in the 6.7 kernel should help us continue to move towards parity.
Unsurprising given recent developments in AMD load scheduling et al.
Cheers!
Awesome, good to know, lurking.
For now I’ve installed auto-epp, which is not perfect but good enough for now.
The reported draw has its own averaging and it’s literally the same data source the battery uses to know the percentage, just more directly.
I have, extensively, just scroll up.
6.7rc3 hasn’t done anything for my test battery
Thank you for this, regarding the things I’ve tried, the one that has been working with the lowest power consumption for me was using ryzenajd + auto-cpufreq however I can’t stand how much slower my laptop is when using it. I tried your suggestions without installing PPD yet, just manually setting the parameters using echo and I got better idle consumption compared to the “stock” I was using which was just AMD pstate passive.
I idle at 8.5W now using the suggestions you gave. I used to get 8.0W with ryzenadj + auto-cpufreq and video playback with that was around 12W with current settings it’s around 17W but I still get a lot of frame drops for 60fps videos, also tried using MPV.
So with regards to idle and overall “feel and responsiveness” of the system, I’m sticking with this and will be trying PPD too. Thank you very much for your suggestion. Really hope the situation for HW video accel improves.
What exactly did you do with ryzenadj? Setting the power limit too low actually hurts efficiency and makes the laptop feel pretty bad.
That is way too high, something is not right there.
I basically used to cap stapm and the others at 5 watts LOL.
Just a bit higher than windows, I idle at 6W on windows, I’m not using a framework yet btw, I’m using an Asus TUF a15 w/ ryzen 7 6800h.
I would not do that, that just makes it less efficient (and the confised hw decoder ignores the limit anyway, it was the first thing I tried when I figured out it was the culprit XD).
On the 7480u the sweet spot seems to be in the 10 to 15W region, capping to 5w gives it bad performance per watt and bad performance, 10 gives it pretty great perf per watt and good performance. Capped to 5 you’ll actually use more power to do the same stuff, I’d assume it’s even worse on the 6000 but it’s not like I have one to test.
That thing got a dgpu that doesn’t idle right or something? 6w idle is still a lot.
Sooo, i am reading this thread again and again but as someone not very experienced in the power saving side i am not entirely able to get actionable bullet points out of it. I tried to randomly screw around and for now i did:
  • disable ppd
  • installed tlp and used the settings someone postet somewhere up here
  • added the amd_pstate kernel parameter
i have no clue if what i did did anything useful. Especially the pstate stuff seems to rely on additional settings i havent done anyway?
furthermore, i have clicked around a bit in powertop and it says all good except “VM writeback timeout” and “autosuspend for usb device hdmi expension card [framekwork]” which i can use with enter and turn “good” but only for the current startup.
While i am writing this i am at 11.8 Watt drawn which seems a bit much when there is nothing going on except a passive firefox and a console with powertop. So i guess i am doing it wrong?
So kind people, what is your collective conclusion so far?
I haven’t done extensive testing as others on here have, but I think the single biggest positive change to my power draw was swapping out to the 6.5 OEM kernel. This kernel has AMD_pstate configured as default.
I thought TLP was making a big difference but I changed back to PPD a few days ago and my idle seems about the same, around 4w.
What console application are you using? I’d been monitoring my draw with BlackBox, which is apparently really poorly optimized as the application seemed to be causing a 4-5 watt draw simply rendering characters! I changed to the Kitty terminal which uses hardware accel and it made a huge difference.
“Konsole”, the KDE one. I am on kernel 6.6.4 I didn’t even realize that the pstate is on per default, so i could just have not added the kernel parameter? I guess the console application is quite relevant for blinking cursor stuff, i dimly remember some story of vscode devouring plenty of power for that effect alone.
Also, when i say “only powertop in a console” i off course mean “a full blown KDE desktop environment with all the panel stuff constantly displaying data and 5% display brightness”
Yeah it was really bad, I really couldn’t stand how slow it is, so now I’ll just be sticking to the optimizations recommended here :grin: feels a lot better though it consumes a little bit more power.
Well that’s how much it idles on Windows w/ the dGPU turned off, on Linux it’s 8W(wish I could get it to 6W like windows haha) but I’ve double checked and GPU really is off on Linux too at 8W.
If it actually consumes less power in you super limp mode means it is also doing less. You may need to have a look at your background tasks or something. the 5w pl puts even the more efficient 7480u way outside it’s best efficiency so it’s probably even worse on a less efficient bin of a previous generation.
You could also try a frequency cap instead
Since the other one stalled I submitted this to PPD.
Here’s a COPR for Fedora 39:
https://copr.fedorainfracloud.org/coprs/mariolimonciello/power-profiles-daemon/
Here’s a PPA for Ubuntu:
Hi @1115, glad things have improved and are more responsive. It may be worth trying powertop --calibrate and once that’s finished see what it reports as the biggest draw.
After looking at that, powertop --auto-tune may also be worthwhile. If you’re happy with the results of that, you could add it to your start-up scripts or via udev for when on battery.
Looking at powertop output and the FW13 with mediatek wifi, I’ve tested turning power management off, which improves performance but also increases reported draw by ~1W.
Based on these specs for your laptop, I would also try a lower refresh rate to see if that resolves the dropped frames (start at 60Hz and then go up from there).
Otherwise, for graphic performance, you may wish to look at folks with the same or similar laptop/cpu to see what kernel flags are in use for the gpu? Or try the proprietary AMD graphic drivers. I have to use them on a desktop for DaVinci Resolve and they have been improving.
This thread regarding gpu firmware may also be worth looking into based on the dropped frames you’re (not) seeing.
Here’s to further efficiency gains!
@Mario_Limonciello Thanks for putting up that MR, I tested it and reported in the MR (hopefully the bump/results help!) Hopefully this gets merged, it makes a huge difference in power draw and will allow for great power saving without needing to configure/manage something like TLP.
