Trouble installing Ubuntu 26.04.1 on FW 13 Pro AMD
I am trying to install Ubuntu 26.04.1 on my Framework 13 Pro AMD Version. I configured the USB with Rufus following the official guide.
I keep getting this error message after the GRUB menu. I have tried different expansion cards in different slots. Plugging in the power prompts a repeat of the error message.
This is my first time installing Linux. Would appreciate any help. Thank you!
UPDATE: I went into BIOS to check the date, it is set to 2025 ish. All components are listed correctly.
However, the ENTER key has stopped working completely now, I am not sure why?
Have you been able to boot into Ubuntu? If so, the first thing I would check is if the keyboard locale is set correctly.
I managed to install Ubuntu after changing the date in BIOS! Very happy it works. Found another thread of someone with the same issue:
The problem with the enter key persists, and backspace and ‘d’ also don’t work, but I assume this is a hardware issue, discussed in this thread:
Will try redoing the input cover!
