Two dead motherboards i3 cpu
Hello everyone. I have a framework 13 and purchased a framework 12 for a teenager to support frameworks mission as soon as pre orders were available.
I purchased the i3 model with 24gb crucial ram and 512 Samsung ssd. SSD and ram were purchased elsewhere.
The laptop was received 7/2025 and was working well until it stopped charging on 11/25. The motherboard was replaced under warranty. The motherboard worked fine until 02/2026 and again it would not charge. Framework is sending a replacement. Have you had dead motherboard/mainboard issues?
I’ve had two FW 12s since the first batch. No issues with the boards.
What charger are they using? Will it stop charging only on one particular port or does it stop charging on any port?
The charger used is the oem framework 60w charger. The motherboards went from no issues to battery draining quickly to completely dead to no response from motherboard. I followed framework support recommendations switching ram, ssd, removing expansions cards, reset, plugging directly to the motherboard, different expansion card but nothing. When charging there was no light indicator but I did feel the usb c expansion as being warm. The expansion cards were purchased refurbished from framework.
