Debian 13
Which release version?
trixie
Which kernel are you using?
6.12.63
0.0.4.2
Which Framework Laptop 16 model are you using? AMD Ryzen™ 7040
First seeable issue: Freon does not report the 180W charger voltage, it is just clamped to 5V or 0V the battery is reporting charging status, from the wattage is calculated over 140W usage, so the HW is working and negotiating well, amper rating always get to 5A.
Second issue after digging:
root@FW16-WJ:/sys/kernel/tracing# cat trace
# tracer: nop
# entries-in-buffer/entries-written: 4/4 #P:16
# _-----=> irqs-off/BH-disabled
# / _----=> need-resched
# | / _—=> hardirq/softirq
# || / _–=> preempt-depth
# ||| / _-=> migrate-disable
# |||| / delay
# TASK-PID CPU# ||||| TIMESTAMP FUNCTION
kworker/4:1-256 [004] … 2776.087270: ucsi_connector_change: port0 status: change=4802, opmode=0, connected=0, sourcing=0, partner_flags=0, partner_type=0, request_data_obj=00000000, BC status=0
kworker/14:2-12098 [014] … 2778.510402: ucsi_connector_change: port0 status: change=4800, opmode=4, connected=1, sourcing=0, partner_flags=1, partner_type=1, request_data_obj=00000000, BC status=1
kworker/14:1-319 [014] … 2778.834544: ucsi_connector_change: port0 status: change=0a42, opmode=3, connected=1, sourcing=0, partner_flags=1, partner_type=2, request_data_obj=42c709c2, BC status=1
kworker/14:1-319 [014] … 2779.402235: ucsi_connector_change: port0 status: change=0240, opmode=3, connected=1, sourcing=0, partner_flags=1, partner_type=2, request_data_obj=92c7d1f4, BC status=1
From this: The Negotiation Timeline
2776.087: Disconnect/Reset (connected=0).
2778.510: Connection (connected=1, opmode=4 “PD 3.0”).
2778.834: Intermediate Negotiation (request_data_obj=42c709c2)
Position: 4 (Likely the 20V Profile).
Current: ~4.5A.
System boots up at 20V (Safe Mode), sometime seeable in freon one brief glitch 20V appears.
2779.402: Final EPR Negotiation (request_data_obj=92c7d1f4)
Position: 9 (The 36V EPR Profile?).
Current: 5.0A.
System successfully switches to 180W.
Another approach:
modified kernel module (added one line debug):
drivers/usb/typec/ucsi/psy.c: static int ucsi_psy_get_voltage_now
switch (opmode) {
case UCSI_CONSTAT_PWR_OPMODE_PD:
index = EPR_RDO_OBJ_POS(con->rdo);
val->intval = pdo_fixed_voltage(pdo) * 1000;
if (val->intval == 0) {
printk(KERN_ERR “UCSI_VOLT_DEBUG: Index=%d PDO=0x%08x RDO=0x%08x CalcVolts=%d\n”, index, pdo, con->rdo, val->intval);
int pdo_type = (pdo >> 30) & 3;
if (pdo_type != PDO_TYPE_FIXED) {
u32 rdo_volts = ((con->rdo >> 9) & 0x7FF) * 20000;
if (rdo_volts > 0)
val->intval = rdo_volts;
} else {
val->intval = 0;
break;
Output when it is connected (supressed other outputs):
[ 1369.044900] UCSI_VOLT_DEBUG: Index=4 PDO=0x00000000 RDO=0x42c709c2 CalcVolts=0
[ 1369.109456] UCSI_VOLT_DEBUG: Index=4 PDO=0x00000000 RDO=0x42c709c2 CalcVolts=0
[ 1369.585152] UCSI_VOLT_DEBUG: Index=9 PDO=0x00000000 RDO=0x92c7d1f4 CalcVolts=0
[ 1369.713070] UCSI_VOLT_DEBUG: Index=9 PDO=0x00000000 RDO=0x92c7d1f4 CalcVolts=0
[ 1370.015427] ucsi_acpi USBC000:00: unknown error 256
[ 1370.273931] UCSI_VOLT_DEBUG: Index=9 PDO=0x00000000 RDO=0x92c7d1f4 CalcVolts=0
[ 1370.336943] UCSI_VOLT_DEBUG: Index=9 PDO=0x00000000 RDO=0x92c7d1f4 CalcVolts=0
[ 1371.960918] UCSI_VOLT_DEBUG: Index=9 PDO=0x00000000 RDO=0x92c7d1f4 CalcVolts=0
The OS is cannot handle the profile above 4 or the profile is not reported by the firmware above 4?
Voltage report bytes are zeroed out, is this by the 180W adapter is fixed voltage EPR or it is firmware error?
Lastly… I am missing something, overreacting or my install is broken and there is some one-liner what will solve this?
