Ubuntu 24.04 issues
Ahoi just want to share my thoughts.
Im running ubuntu 24.04 on AMD 7040 Series
Fan:
I had fan-issues GitHub - TamtamHero/fw-fanctrl: A simple systemd service to better control Framework Laptop's fan(s) solved my issue.
Not sure if this was the reason my batteries died.
I would like the idea to see this documented. I would love to have framework repository for distributions, they claim to support to have this out of the box.
The other thing is the touchpad.
$ sudo libinput measure touchpad-pressure
Using PIXA3854:00 093A:0274 Touchpad: /dev/input/event7
This device does not have the capabilities for pressure-based touch detection.
Details: Device does not have ABS_PRESSURE or ABS_MT_PRESSURE
So no way to to configure palmpressure.
The timeout should be 2 seonds while typing but it is under a second.
Anyone has the same issues?
Have you got another output for libinput.
Maybe the touchpad is broken after 2 swollen batteries.
