Ah, the Copper Shim sandwich. XD I’ve skimmed the article and saw it mentioned, but I haven’t found a full breakdown on how to do it yet.
Also, where would I source the copper from? I imagine I’d have to cut it to size myself, yes?
This is what I used, I didn’t cut any metal and just left it a little oversized. I did sand it down though, but I’m not sure how much that actually did for the performance.
Excellent! Thank you so much for the quick response! I’ll be sure to report back with how it goes. I’ve barely been able to get over 30w without the fans going to the moon.
Yeah man, i invented the mod and you find it fully broken down with steps here in the thread under my name. I made those posts in 2024 in August or October i don’t really remember anymore. But if you have genuine ptm and a 20x20x0.8mm coppershim you are good to go. Just lap and polish the shim on a flat surface as its not completly flat due to manufacturing and lap the vaporchamber as clean as possible. Than you put the shim like CPU-ptm-shim-ptm-heatsink into your device. Screw it down, heat and cool it for some days and recheck the screw tension after some days and you are done. You should feel and here a difference from the get go as the device stays alot less audible on daily use.
I did the same mod around the same time, can confirm. This is the way.
Here’s the immediate before and after on Cinebench and HWinfo. Apparently even without the shim, I could still pull 50w under a stress test, so I guess it wasn’t that bad. The CPU was able to stay a little cooler, and I did loosen a couple of the MB screws that seemed to warp the board, as I saw that mentioned elsewhere in the thread. I’m assuming the four screws for the heatsink itself should remain tight.
What’s really interesting is the split between the CPU cores is still pretty bad, but even on the liquid metal, Core 5 was always much hotter than the rest, but with the copper shim, it’s now Core 4. The averages on these are a little wonky since I didn’t get the screenshots exactly at the same point.
I’ll report back in a few days to see if it gets any better XD
Those are some good results!
@PSierra117 I have some questions regarding the shim if you dont mind:
Yes it is worth it, you get more even temps about the cores and a performance bump by about 5%. The Original Shim is due to its mounting to the vapor chamber in smaller Area than the Chip itself and therefore increases the Thermal Resistance.
Its worth it but, not needed! You get the full Power designed when just using the PTM as is. (54w-45w) To get the full Potential of the Mod, you need to change the tdp limits and timings, but even if you don’t mess with the settings, you get a quieter device in normal Day use outside of heavy loads.
You need 1 sheet of thermalgrizzly Phasesheet or equivalent Genuine PTM, its enough to do the mod 3-5 Times.
You can use the Device like normal directly after the mod, It reaches its full potential after about 10 Heat Cool Cycles, but its in the 1 Digit percentage. A Cool Cycle is when the Chip gets below 45C and a Heat Cycle is when it goes above 70C.
To answer some of the other questions, no PTM is not reusable. For clarity, when Sierra says it’s “enough for 3-5 times” I assume he’s referring to the size of the sheet having enough space to cut 3-5 smaller pads out of.
@PSierra117 what do you use to modify the TDP limits? I haven’t done this, and I wouldn’t be surprised if that’s why my CPU sits at 75-85c during a cinebench run (scoring ~15.1-15.4k) but still doesn’t pull more than a sustained 45W.
Github - Smokeless_UMAF Is the Tool to modify the TDP Limits, I run unrestricted up to 80W until i hit Thermal-Limit at 98C and up to 58/60W sustained. But those Numbers are not really represented in Cinebench Results, the Margin gain flattens with higher tdp. So up to 65W Peak and 55w sustained is a reasonable Limit.
But for Disclaimer, you are in Device Breaking Territory when using smokeless umaf. Those UEFI Settings are hidden for a Reason.
Yes i definitly meant the size of the sheet is enough for more than one use, but the PTM is one Use only.
With “sheet” you mean a 50x40mm sheet? I probably cut it to the CPU heat spreader size, right?
Thanks!
I’ve already made a number of hardware/software/ and firmware changes to my device. This is one that’s been on my radar for a little while now. Thanks for the tip!
Yeah, you cut to to match the size of the smallest part you’re joining. E.g. for connecting the CPU die to the shim, you would cut it to the size of the CPU die.
Note that academic papers have researched different cutting methods, and it’s recommended to cut with a fresh exacto style razer, and not with a pair of scissors. A rough cut negatively impacts the thermal performance by affecting the structure of the phase change material at the edges.
nahh don’t need to be scientific. Just cut it a bit bigger than the die with a pair of scissors and wing it. Its really no that affecting. I have done it so damn often. As the PTM melts and gets pushed out under the pressure plate its building walls with excess PTM. The material between the shim and the die will gets thinner than 200 micrometer after some heatcycles.
I suppose if you oversize it then yeah, the effect of the edges is a non-issue. There’s plenty of material for it.
I’m sorry….. But what?! LMAO.
Even if cut slightly smaller, it sqwishes out so any microscopic cut anomalies will matter 0%.
If anyone’s interested in reading for themselves, I’m referring to some work done by Igor’s Lab.
Well Igors Test is a bit exagerating, yes it is technically right, but a sharp pair of scissors works fine every day. I did it with a scalpel when i started using PTM, but using scissors is faster and in reality it doesn’t really bond the backing film to the ptm.
A Better Tip would be to have the PTM in the freezer and clean the Die and Shim with IPA. The IPA helps to prep the surface for the PTM to stick more. And having the PTM in the Freezer before install makes it even easier to peel the film.
What settings did you change, and where did you find them in the menu? I tried setting fast and slow PPT, but it didn’t seem to do anything.
I found this guide, but I’m not convinced disabling c-states is necessary. Reddit - The heart of the internet
