Which Linux distro are you using? Secureblue, based on Fedora 44 atomic
Which kernel are you using? 7.1.3-200.fc44.x86_64
Which BIOS version are you using? 4.02
Which Framework Laptop 13 model are you using? AMD Ryzen AI 300 Series
I have USB-C port extension cards on slots 1, 3 and 4. I usually charge using slots 1 or 3, depending on where I sit.
However, when I plug my USB-C cable, half the time, it doesn’t work and I have to flip it over, and then it charges. So far as I know, USB-C cables and ports are two-sided, so I should be able to charge whichever way the cable is plugged in, right?
