USB C port on slot 3 (rear right) disapear after unplug the cable
Which Linux distro are you using? Gentoo
Which release version?
recently
Which kernel are you using?
Linux framework13pro 6.18.57-gentoo #1 SMP PREEMPT_DYNAMIC Sat Oct 24 12:21:38 AEDT 2026 x86_64 AMD Ryzen AI 9 HX 370 w/ Radeon 890M AuthenticAMD GNU/Linux
- Vendor: INSYDE Corp.
- Version: 04.02
- Release date: 06/09/2026
Hi,
Both my slots 1 and 3 are USB-C extension cards. The USB-C port in slot 1 has worked fine so far. I connect it to my LG display and my monitor, and all connected peripherals work well.
However, slot 3 only works once after a fresh reboot. If I unplug the device, the system effectively loses the USB-C port. No matter what I plug in, a USB drive, keyboard, or anything, the system shows no event at all. Its function is restored after a reboot. But it only works as long as I keep the device plugged in.
I found another post that also mentioned an issue with slot 3. But I don’t know if it is the same issue, and that post is very old.
Thanks
