USB4 and Thunderbolt on AMD
The linked thread is about the AMD GPU driver not doing things correctly. Would not affect NVMes.
But I have no confirmed the following:
It attaching as USB3 device on my Maple Ridge TB4 host seems to be the hosts fault, as expected. When I disable ASPM on that mainboard again (as is the factory config), it works reliably with PCIe. It seems, not only causes this mainboard bluescreens if you activate ASPM for an Nvidia GPU it also messes with a bunch of devices behind TB/USB4. This Asus mainboard is just completely broken and they should be sued for how they disable and block power saving options and try to hide it, as that leads to default settings that actively break the law.
Secondly, the ASMedia app shows the ASM2464 consistently in TB3 mode when it only comes up with 2 lanes. This is also true behind my USB4 hub and for the USB4 host and the TB4 host.
Why it recognizes even a TB4 hub with the Windows USB4 drivers as TB3 might have sth. to do with the firmware on that hub, not sure. But either way, the forced limitation to x2 still seems problematic in and of itself (and I am guessing that is done by the ASM2464’s own firmware and might not have been true for older firmwares).
The problem there is that something takes the fake bandwidth the USB4 root reports literally, which is potentially the case here too.
There are a bunch of firmwares floating around you could try if you wanted to confirm that.
I have not noticed any difference between them but I only checked performance on win11 and if it would hotplug on linux.
I already tried a few.
That also changed the name of the device and Satechi themselves does not publish any, even the original 10.05. firmware it shipped with (that connected only with USB2 to my TB3 host).
The december firmwares (12.04. & 12.18.) fixed that. Currently on the 01.29. in the hopes that that would be the TB4 certified one, but unsure.
Questionable that Jeyi even depublished their firmwares for the ASM2464…
That could explain problems in linux, but not how my Windows hosts are affected.
With a native USB4 connection and x4 working, I still see the virtual x1 gen 1 connections in between. The PCIe topology with TB3 is identical. So no reason that the NVMe driver or sth. else would change its behavior, because it will only see PCIe and have no idea if that device is behind any TB/USB4 connection let alone what type of actual wire speed is used on that connection.
With TB4 hub in between, ASMtool shows TB3 mode, x2 lanes on actual SSD, x2 bandwidths
Without TB4 hub in between, ASMtool shows native USB4 mode, x4 lanes on actual SSD, x4 bandwidths.
On windows everything works fine on my end so I guess we don’t have the exact same issue.
Did manage to try with a pcie4 ssd (PM9A1) and that did 3.8GB/s read and 3.7GB/s write which afaik is pretty close to the theoretical limits of USB4. Unfortunately just on windows.
That isn’t an issue on windows but it would explain the dmesg entries about speed limitations.
Update: Holy moly hotpluging works with the other ssd.
Update2: Tried a bunch of other nvme ssds, all worked it’s just the 970 evo that doesn’t. The 2GB/s cap is still there though.
Very curios as 970 evo 500GB is the SSD I am using, because all my other (and Gen 4) SSDs are encrypted and inside my FW or deep in my desktop. I could get WD SN700 500G SSDs more easily, but those are also just Gen 3.
There is another thread with someone having the issue with a 970 evo plus, and iirc some pople had issues with them in realtec enclosures. That thing may just be cursed.
However my problems are apparently different from yours, I never had anything to do with 2x.
Have you found what is limiting your bandwidth instead? Not getting over 2 GiB/s seems suspiciously like a limitation to either 20 GBit/s or PCIe x2 Gen 3 or x4 Gen 2.
This line in dmesg looks pretty suspicious. But I have not seen anything about 2x in lspci or boltctl or dmesg or anywhere else I looked.
[ 2043.958225] pci 0000:64:00.0: 2.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x1 link at 0000:00:04.1 (capable of 63.012 Gb/s with 16.0 GT/s PCIe x4 link)
It does kinda look like an artificial limit since I get 2.00GB/s on a dd read, 2 on the dot which is more than a pcie3x2 link has even before you factor in overhead and way less than a pcie4x2 has.
Update: It gets even weirder, I just upgraded to kernel 6.8.2 and it just read the whole drive (512GB PM9A1) at 2.4GB/s, so I guess it pretty much definitely not pcie3x2 in my case.
I just picked up an Anker TB5 hub for Prime Day and it’s working great on my M3 Macbook: DisplayPort + Ethernet + Thunderbolt 4 RAID drive…magnificent.
Plugged it into my AMD 7840 Framework 13 (running Arch Linux) and all I get is power. :frowning: Even USB2 speakers and a microphone go unrecognized…is this expected? I see throughout this thread that USB4 is compatible with Thunderbolt 4, but maybe not? Do I need an Intel mainboard if I want to use this hub?
I assume you use the correct port on your Framework?
That dock is listed as TB5 and TB4 compatible. USB4 is technically Thunderbolt 3 based. Maybe that’s why it doesn’t work.
I tried both USB ports (left and right) that are closest to the hinge, which should be full USB4/Display.
The person in this post says they got it working on their FW13 as long as they didn’t use a TB3 cable…but didn’t say if they’re running Windows or Linux on their FW13.
Mention of dmesg…so Linux.
Oh yeah, duh. haha I swapped the stock TB5 cable with a USB4 and now lsusb lists a couple of new things:
Bus 007 Device 008: ID 1d5c:5801 Fresco Logic USB2.0 Hub
Bus 007 Device 009: ID 291a:83b5 Anker Anker Thunderbolt 5 Docking Station
But nothing that’s connected to it (ethernet, speaker, mic, DP monitor) show up. I tried only plugging in one at a time but still nothing.
TB4 & 5 are implementations of USB4. So that should 100% be compatible.
The question is, is that a Linux problem or not (because the hub is USB4v2 instead of the USB4v1 of the host controller and what I have seen Linux run so far.
Some part might get confused by that (would be a bit and against the spec)).
What happens in the non-USB4 ports? If they work it’s likely a USB4 problem, not a PD problem.
Other than that debugging the Linux thunderbolt driver by loading it with the “dyndbg” command line option. Then it will log a lot into dmesg. Where you can tell where in the process of USB4 negotiation it fails. Because there is a hardware/firmware level to this, where the physical USB4 connection gets negotiated and then there is the connection manager part, which is implemented in the OS driver, that then needs to discover all the features and setup tunnels so that you can actually make use of the USB4 connection.
I suspect you’re hitting the bug that broke hotplug events. There is another thread on it. The patch fixing it isn’t landed yet in stable kernel.
Try running “lspci” as a workaround.
Here is the link to that other thread.
Thanks everyone! I just left for a trip but will give these suggestions a try when I get home. I also ordered a Caldigit TS4 (thank you Prime Day!) which has had lots more time for folks to figure out fixes.
I was summoned from the other thread… yes, I have the Anker TB5 and it works great with a USB4 cable. I’m using Cable Matters.
If you are looking to debug Thunderbolt/USB4 you probably want to try these tools: GitHub - intel/tbtools: Thunderbolt/USB4 debugging tools
While they are from Intel they work just fine on my AMD HX Framework. tbman is the nice interface to seeing all this data.
