VRR on Framework 13 Pro capped to 70fps when enabled on Linux
I’ve noticed when enabled VRR on Hyprland, my max frame rate suddenly becomes capped to 70fps, no matter what I do, even if the monitor is set to 120fps mode. Disabling VRR fixes the issue immediately and allows rendering to continue at 120fps immediately. Initially I thought this was related to Hyprland, but there seem to be reports of this issue occurring on a variety of desktop managers and distributions, all on Linux.
Which release version?
06/27/26
Which kernel are you using?
7.2.0-1-cachyos
3.20
Framework 13 Pro Intel Core Ultra Series 3
