We want a battery case!
Why stop there, if we are going to lie why not go for the 99999mah ultraFire, I am really impressed that actually works but people do buy them.
For reference the highest capacity 18650s were 3600mah (The legendary/mystical Panasonic NCR18650G) and are pretty much unicorns. 3500mah cells are relatively available from all manufacturers.
Absolutely. The batteries are very slim so stacking two of them in 1 enclosure makes sense.
@moderators i think this should be split into its own topic, super interesting!
Are those still 5V so no fast charging? Can’t they be hooked up in parallel (or serial? always forget with batteries) to boost the voltage?
18650s are raw batteries so around 2.5-4.2V ish. No fast charging or charging at all for that matter and definitely not 5V XD.
They can and are put in series to increase voltage for a lot of applications.
55Wh x2 = 110 Wh, which is too large to take on an airplane IIRC.
That’s why modularity is so great! Just hand one battery to a friend, or one in your lugage and one in your backpack. :slight_smile:
Can’t you have as many as you want as long as they are under 100wh? Afaik the limitation for sub 100wh batteries is “reasonable quantity”. Apparently you can also have up to 2 160wh batteries with most airlines but looks like noone does that.
I personally feel that 1kWh worth of extra batteries is reasonable quantity. :exploding_head:
Lithium batteries are prohibited in checked luggage in the US. Other parts of the world may have different restrictions.
The one in your luggage (I presume you mean checked luggage) will go missing, and you will find a note when you get to your destination that it has been removed by airport security. Had exactly this happen with a spare camera battery I managed to leave in my checked baggage.
Just ordered the new 61Wh battery. Would love to have a case for my old one!
I’d appreciate if someone at the framework team could at least publish a rough schematic of the battery case demo unit, that way people who wanted to make their own DIY version would know what components to get.
wait
They have a demo unit?
I have been living under a rock! What else are there?
IIRC they showed it off at the same time as the original 3d printed case for the mainboard as a proof of concept.
So I know you can DO it, I just wish they put cad files and a parts list on github or something for those of us without degrees in electrical engineering.
Is there any chance we can ask someone on the framework team to give a parts list or cad files for the battery demo unit like they did for the mainboard case?
I’m not asking for them to roll it into production, I’d just like a DIY guide so I can reuse my old 55wh battery without zapping myself.
According to upower -d on Fedora 39, my 2021 55Whr battery only holds an 88% charge- I hope I can replace it with a 60Whr battery and put the old battery into a battery case too!
Device: /org/freedesktop/UPower/devices/battery_BAT1
  native-path:          BAT1
  vendor:
  serial:               wo
  power supply:         yes
  updated:              Thu 14 Dec 2023 02:00:13 PM MST (8 seconds ago)
  has history:          yes
  has statistics:       yes
  battery
    present:             yes
    rechargeable:        yes
    state:               discharging
    warning-level:       low
    energy:              5.4208 Wh
    energy-empty:        0 Wh
    energy-full:         48.9412 Wh
    energy-full-design:  55.0088 Wh
    energy-rate:         11.8272 W
    voltage:             14.344 V
    charge-cycles:       3
    time to empty:       27.5 minutes
    percentage:          11%
    capacity:            88.9698%
    icon-name:          'battery-caution-symbolic'
  History (charge):
    1702587523	11.000	discharging
  History (rate):
    1702587613	11.827	discharging
    1702587583	11.719	discharging
    1702587553	13.182	discharging
    1702587523	17.186	discharging
it is now Feb 2024 and I feel the same
Hoping this concept becomes reality! I wonder if there are any legal or safety issues with designing the enclosure? I’m sure they’ve got enough on their plates with the 16 so maybe it’ll come with the next generation parts
I’m happy with my 55Wh battery in my 11th gen machine.
But if I want to upgrade or have to upgrade due to low capacity I would only do so if i can reuse the battery in a powerbank case.
