Weird Charging/Battery Drain Issue
I have a rather odd issue that I’m curious to know if anyone else has with their AMD 13-inch laptops. I have two 7840U boards and a 7640U board that I’ve been using the last year or so, mostly plugged in, and I noticed that one of them have a rather high cycle count given that it’s always plugged in. Upon further investigation, what appears to be happening is it will charge up to 80% (the limit I set in BIOS) and once it stops charging it will run off of the USB input power for a bit, but within a few minutes will start drawing power from the battery and reduce the power being puled from the charger. Then, it will drain to 75% at which point it will start charging again, up to 80%.
A bit of additional information on some things:
  • I verified that the input power drops when the battery is draining with one of those USB power monitors; it won’t drop to zero but to around 3-4 watts with the battery picking up the rest. This happens even if I leave the laptop idle.
  • I normally use a Dell Thunderbolt 4 dock (WD22TB4) but also happens with any other charger I’ve tried, including a 140W Ugreen charger.
  • This behavior is NOT observed on the other 7840U nor the 7640U laptop with exactly the same bios and operating system configurations. They will charge to 80% and stay there, not drawing power from the battery at all.
  • All of the laptops are on the same bios and EC version (3.17)
  • Battery power/usage readings are from upower.
I don’t plan on doing any other testing at the moment as I’ll be swapping out both the mainboard and battery in a week or so and I regularly use this machine, so I’ll test it externally once it’s been swapped out. At the moment I’m just wondering if anyone else has experienced this issue.
Lastly, I don’t believe this is relevant as I don’t believe the battery charging can be controlled directly by the OS (and therefore didn’t tag this with Linux), however everything is running up-to-date Arch Linux installs currently with kernel version 6.18.2-arch2-1, though this has been happening for a while.
Edit: Here’s the output from upower showing the battery draining while in pending-charge status:
% upower -i /org/freedesktop/UPower/devices/battery_BAT1
  native-path:          BAT1
  vendor:               NVT
  model:                FRANGWA
  serial:               XXXX
  power supply:         yes
  updated:              Wed 24 Dec 2025 12:25:45 PM MST (6 seconds ago)
  has history:          yes
  has statistics:       yes
  battery
    present:             yes
    rechargeable:        yes
    state:               pending-charge
    warning-level:       none
    energy:              44.5824 Wh
    energy-empty:        0 Wh
    energy-full:         58.1119 Wh
    energy-full-design:  60.6042 Wh
    voltage-min-design:  15.48 V
    capacity-level:      Normal
    energy-rate:         7.83288 W
    voltage:             16.346 V
    charge-cycles:       150
    time to empty:       5.7 hours
    percentage:          77%
    capacity:            95.8876%
    technology:          lithium-ion
    icon-name:          'battery-full-charging-symbolic'
  History (rate):
    1766604345	7.833	pending-charge
    1766604315	7.786	pending-charge
    1766604285	7.353	pending-charge
    1766604255	7.074	pending-charge
