I disassembled the USB-C and USB-A and they are just extension cables, you can plug a USB-C device directly onto the mainboard. How does an empty USB-A draws current? I found that the top surface on the USB-C expansion card is plastic while the top surface of the USB-A is metal, does that affects grounding? What will happen if I swap the top serface i.e putting the USB-C expansion card cover into a USB-A expansion card?
EDIT: Where can I find Expansion Card Functionality on (11/12/13th Gen Intel® Core™)? There is only an Expansion Card Functionality on Framework Laptop 13 (AMD Ryzen™ 7040 Series)
A USB-A card needs to tell the USB-C controller that it’s present so that the controller falls back to compatibility. It does this through a resistor on the CC line. Unfortunately, this causes the AMD compatible retimers to be unable to sleep.
Metal was used for the USB-A card only due to being thinner, needed to accommodate the USB-A port height.
All slots are supposed to be the same on the Intel boards.
