I have been looking for details on the 240W adapter, specifically the dimensions.
I searched a while, but can’t find the information (strange actually).
What are the dimensions of the 240W adapter? Anyone knowing them, or has a link to the spec? Thx!
Fixed outputs from 5V to 48V and AVS support give you wide device compatibility, while the included 2m USB-C and 1m AC cables keep things flexible. All this in a 150 × 58.2 × 27mm, 400g package.
