XADE
June 7, 2022, 10:30am
#1
there has been many requests for touch screen displays with higher refresh rates
I’ve a strong feeling that the team is already working on it
however, many have also been requesting for OLED displays
Why OLED is not an ideal choice for a long term device ?
OLED :
cons :
1st letter O stands for organic
will degrade over time, short life span
vulnerable to water damage
cannot sustain high brightness
burn-in : permanent image retention
screen flicker
for more details click here
each & every oled implementation need not to share each & every con eg. AMOLED
Here are my suggestions :
mini-LED :
pros :
not prone to burn-in
smaller than the LEDs, provinding granular backlight control
good contrast & deeper blacks
can sustain high brightness
cons :
still rely on LCD
contrast is not as good as OLED
micro-LED :
Best display tech without cons, yet to be proven
for more on display technology checkout AndroidAuthority’s article
feel free to agree or disagree below : )
amoun
June 7, 2022, 10:47am
#2
XADE:
high power consumption
screen flicker
I think that nay have been true a decade ago, what references do you have to support each of those claims, in 2022 ??
For example
The lifespan of an LED is approximately 8-13 years. The lifespan of an OLED is about ten years
OLED Vs. LED Lifespan: A Detailed Comparison Of The Two Display Technologies
Many mobile phones use OLED and are much more likely to get wet and that doesn’t seem to be an issue.
This is my first OLED and my biggest concern was brightness . I kept reading so many things about OLEDs not getting bright enough. Yet, this thing is super bright! SDR content is perfect, even in my bright living room during the day, and HDR content is crazy bright.
XADE
June 7, 2022, 11:04am
#3
here is the answer
even though many of the cons might have been diminished, but O in OLED still stands for organic in 2022
