I purchased a 16 inch laptop 2 years ago and am very happy using it.
Since like 2-3 days, the wifi started to weaken (long time to connect, sudden drop a bandwidth…) and today, wifi was unusable.
There is no reason to be a software problem, so I decided to open the laptop.
It is then with an unfortunate surprise that I discover that the battery is not screwed in, last time I opened the laptop was like 6mo to 1y ago.
So I screwed the battery back and now, wifi works, but only on 2.4GHz and bandwidth is slow (even for 2.4).
I have no problem with replacing the wifi module, and I have not noticed any other issue.
But I’m concerned with the motherboard.
What do you recommend?
Battery not being screwed down is not as big of an issue since it was sandwiched in the machine really well. Glad you found it and secured it.
The other antenna may be loose or not connected fully on the WIFi card. Personally I swapped the RZ616 card that came with mine and got the Intel AX210 wifi card. It was only and I think still is $20! It is a cheap part to replace. Wifi cards can go bad or loose strength over time with just how higher powered radios work. Think like a wifi router in a home. After a few years they cook themselves sometimes. Just a few options for you and the hardest part is getting the little antenna cables connected again!
Hello pkunk,
Thank you for your response, i disconnected and reconnected the antennas and now, bandwidth seems good, 5GHz is back!
That’s really reassuring!
I may upgrade the wifi module later, but for now it’s fixed, to also purchase the oculink module.
