Wifi nonsense lately
Arch
6.17.9
AI Ryzen 370
Wifi 7 card from AMD
The last week has been horrible for Wifi. On/Off/On/Off/On/Off just cannot seem to hold steady. Anyone else experiencing this kind of flake behaviour? Curious if this is a regression in the Driver code for the Wifi card. It was stable and reliable for a few months there, without this kind of on/off/on/off nonsense.
Hello David,
There are two things which help. They either work separately, or in combination with each other.
  1. Disable wifi power saving
    Wifi cards have power-saving functionalities. They can be disabled. If you are using NetworkManager, create the following at /etc/NetworkManager/conf.d/powersave.conf
[connection]
wifi.powersave=2
  1. Setting the correct regulatory domain
Make sure you set the right wireless regulatory domain. Each country’s government allows for different radio frequencies to be used for Wi-Fi. If you check the optional dependencies for linux, you can see the package wireless-regdb. Install the package, and uncomment your country in /etc/conf.d/wireless-regdom.
