Will broken screw shank eventually cause a problem for my 4kg hinge kit?
I recently got the 4kg hinge kit for my Laptop 13 to fix a worsening issue with the screen falling back. (I’ve read the reports about manufacturing issues, but I don’t believe mine was in the bad batch and it’s only worsened after a few years of heavy use.)
Everything went ok with the replacement thanks to the guide. However, when I went to remove the existing hinge, I saw that the head of one of the little screws which attaches the hinge to the top cover had come completely off. See image.
The threads of the screw were still stuck in. I tried my best to get it out with a tiny tweezer, but no luck (I didn’t have super glue on hand to try it out). Is this something I should try to fix? Will it weaken the hinge over the long-term? Or is it probably fine to carry on without this screw?
To be clear, it is the left-most screw highlighted in this image.
(When they shipped the hinge kit, they included two of these screws, so I’m guessing they snap a lot.)
(sorry for the wrong tags, but the Laptop 13 forum says to post here and I couldn’t find any relevant tag!)
Structurally it is best to have all of them per the design, that is not to say it will probably work fine without it. I would just not want a torsion on the screen if it became weak on that side and was still strong on the other.
I don’t know how one would get a pair of vice-grips tiny enough to even grab onto it. Possible a slot could be ground in the shaft and then try to unscrew it with a slotted screwdriver? Otherwise it would looked like drilling it out and maybe retapping it. Though at that point the top cover might just be less expensive and less frustrating.
The problem with small screws like this is how to get the turning force while also pressing down a little and at the same time not weekening the part.
To this end, max turning force is from the outside edge, with no turning force towards the centre.
So, do not cut away the centre, leave it for added strength.
Make small cuts into the opposite edge of the screw.
There are tools that fit the edge cuts available.
Then, to remove it, push down slighty to ease the threads and the turn really really slowly, with only just enough force to turn it. Any more will just damage the head.
I don’t think using glue will help here.
The other option is drilling/etching out the screw. But you need really fine tools for that, so you would probably need a machine shop to help you.
The cheapest option might be just getting a new top cover.
Thanks everyone. Glad it isn’t just my clumsy fingers that are the problem. I’ll make another try with grooves and then consider getting a new top cover.
