Will it be possible to use a M.2 2230 in the Framework 13 Pro?
I have a Framework 12, as I wanted to have a touchscreen. As the FW13Pro got a touchscreen I am thinking if I should switch to a FW13Pro.
As storage is extremely expensive nowadays I wonder if I could use my SN770M NVMe - M.2 2230 - 2TB from the FW12 in the FW13Pro. So I could save some money.
So, is it possible to use a 2230 in the FW13Pro, or are only 2280 supported? I know 2280 will have benefits, but as said: the 2230 is here :wink:
Thanks
They sell extender boards, which provide an extension of the screw down end of SSD modules. If you buy one of those, it should work.
Worst case you can always just tape it down but as mj said you can buy or print extenders.
Thanks! :wink:
