Battery Management with min/max limits possible?
Hello,
I dont have a frame.work laptop yet but I would like to know if it is possible to set a min/max charging limit such as Lenovo has - I dont want my battery at 100% all the time as my laptops are mostly on the charger.
Kind regards,
Sascha
Unfortunately, there’s no min limit (Start charging threshold). In [repeated] high load / boost situations, the laptop would go into trickle charge cycles.
In order to minimize occurrence of trickle charge cycles, you’ll need to get a higher wattage USB-PD charger.
The EC seems to have a process to check battery charge level on a regular basis. If current charge capacity < threshold, it turns on charging.
The battery charge capacity drops when the full system load is greater than the wattage the USB-PD can supply.
If you run a combination of, say, Furmark and ( prime 95 cycles, start 2 minutes, stop 1 minute) *, you’ll see a drop in the battery capacity…and charging will toggle.
  • The start-stop 2-1 thing is to simulate repeated PL2 / boost, while allowing tau to replenish.
This creates an momentary system peak load > 65w (OOTB Framework USB-PD adapter).
The higher wattage charger basically closes the gap between its maximum wattage and the system peak load…meaning the battery will only discharge in those relatively rarer occasions that the system is using more than, say, 90w. (If my new USB-PD is a 90W charger)
Update:
I re-read the “Surely” part… that’s a ‘maybe’.
The ‘smart’ battery IC (not so smart really) doesn’t really know anything about the self-discharge capacity that’s lost. So, when it’s reporting the battery capacity, it’s reporting the capacity of the battery without being aware of the battery’s actual self-discharge capacity lost. As such, the USB-PD trickle charge scenario doesn’t kick in…because the battery is still reporting it as if it’s full / at the upper charge threshold level.
To my limited knowledge, some li-po battery chargers will look a combination of other factors such as voltage, charging current / internal resistance of the battery (?) to determine if charging is needed. These don’t look at a digital counter of the battery capacity.
So, going back to the “surely”… Unless this is implemented, then the EC only looks at the capacity reported by the battery’s IC to determine if charging is needed or not. So under normal use (without high / peak load), I don’t believe* trickle charge with occur with the Framework laptop.
This is also why Lenovo ThinkPads (and from the IBM days) have the “Reset” / calibration function as a “Battery Maintenance” feature, to reset that IC capacity counter (it doesn’t know the self-dischange delta).
In short, that battery capacity from the battery is always a ‘best’ estimate.
Some boring reading:
One other thing that’s missing in the current battery implementation is a charge cycle counter. There’s no way to even subjectively judge the age of the battery at the moment.
Update: Got corrected about the battery counter (below).
There certainly is a charge cycle counter!
% ectool battery
Battery info:
  OEM name:               NVT
  Model number:           Framewo
  Chemistry   :           LION
  Serial number:          00CD
  Design capacity:        3572 mAh
  Last full charge:       3399 mAh
  Design output voltage   15400 mV
  Cycle count             89   <========
  Present voltage         17526 mV
  Present current         3 mA
  Remaining capacity      3399 mAh
It’s not currently surfaced through ACPI, however, and I’ve requested that it do so: Feature Request: ACPI `_BIX` to report battery cycle count
LOVELY!! So I can get that detail. REALLY happy to see this.
Did you get confirmation from Framework as to whether the request will be implemented, and by when it can be expected?
Sorry, the only information I have is that which is in that thread. :smile:
