Fidget Spinner Expansion Card
  • Spins
  • Fits in any Framework Laptop Expansion Card slot
  • Works with or without ball bearing
  • USB-C ports for modifying spin, works well with other Framework Expansion Cards
Printing Tips
  • Printed originally on a Prusa Mini. Supports should be enabled. I found the best results with the bottom USB-C port when I added an exclusion to its supports.
  • It’s not required but you will probably have better spins with a real fidget spinner bearing.
Download
Sources
Haha this is awesome!
But will it do double Ethernet’s?
Ooh, and can you add spots on the “left” and “right” so it can hold four?
I’ve only got one Ethernet card, but it does spin nicely with it if your hands are large enough. Two would be a dream.
I thought about adding four but it could be a bit difficult since the other two sides have the sliding rails.I think it could still work though.
Maybe that and a print-place-design would be a nice upgrade.
Small update - I’ve uploaded a new version where the handles have threads and can be screwed into each other (previously they were forced into each other and were prone to breaking).
