10Gbit Expansion Card negotiates 5Gbit link
Hi everyone!
My new Wisdpi 10Gbit expansion card won’t negotiate above 5gbit and the resulting connection is not very stable.
I’m using a Pro13 Intel Ultra X7 358H, running Fedora 45. My kernel version is 7.3.3 and the card driver listed by ethtool is r8152. There is no firmware listed by this command and the driver version is reported as the kernel version (as I assume is correct for an in-kernel driver).
The negotiation process is clearly struggling, as it take about a minute for the unit to negotiate with my switch. The auto-negotiation settings in network manager is set to ignore: setting it to manual or to auto leads to a failed negotiation and no connection.
I naturally switched ports around the laptop, but as I understood all ports offer the necessary 2x2 bandwidth for the 10gbit link.
I read on the forum some users extracted the firmware from the rtl8159 driver and incorporated with theirs and got the unit to link to the 10gbit, but it seems with some instability. Also, I assumed this was the workaround needed before kernel 7.2.
I verified the unit is not faulty (it links to 10gbit during boot up and the link resets and downgrades to 5gbit when in the OS).
Has anyone else running Linux experienced this? Has someone using Linux right now got a 10gbit link out of the box? Any suggestions?
Thanks!
