While your temperatures look a little high, the max clock looks about right. Here are the results from my 1260P running stress -c 16 with results from turbostat. It ends up settling at about 2.5-2.6GHz. I ran this in my normal config, open on an elevated laptop stand on Arch Linux w/ Sway (curent ambient temp: ~25C)
I’ve included the exact turbostat flags I’m using because otherwise its output can be a bit much:
# turbostat -c package -S --show Avg_MHz,Bzy_MHz,TSC_MHz,PkgTmp,PkgWatt,CorWatt
Avg_MHz Bzy_MHz TSC_MHz PkgTmp PkgWatt CorWatt
5 1460 2496 37 0.91 0.25
11 2079 2496 37 0.99 0.49
5 1668 2496 37 0.95 0.27
5 1550 2496 37 1.00 0.26
523 3269 2496 69 8.61 7.60
3339 3347 2496 82 50.21 48.63
3322 3329 2496 89 51.82 50.00
3240 3248 2496 97 49.72 47.76
3227 3235 2496 100 49.93 47.96
2773 2780 2496 85 35.20 33.22
2556 2562 2496 82 27.74 25.89
2566 2572 2496 81 27.87 26.05
2568 2574 2496 79 27.93 26.09
2573 2579 2496 79 27.97 26.15
2577 2583 2496 78 27.98 26.20
2575 2589 2496 76 27.99 26.25
2579 2585 2496 78 28.00 26.24
2580 2586 2496 76 28.00 26.19
2583 2589 2496 78 28.00 26.28
2582 2588 2496 76 28.00 26.22
2582 2588 2496 76 28.00 26.21
2573 2595 2496 78 28.00 26.26
2584 2590 2496 76 28.00 26.29
2583 2589 2496 78 28.00 26.26
2584 2590 2496 78 28.00 26.29
2583 2589 2496 76 28.00 26.25
2581 2587 2496 76 28.00 26.22
2581 2587 2496 76 28.00 26.21
Things to note: the hard PL1 (sustainted) limit for the framework is 28W. If you are reaching that, then you are not being thermally limited. The PL2 is 64W, but the time window for that is 2440 micro-seconds (~0.0024s) if I’m reading it right. You can see that for my CPU, basically it holds about 50W for about 20s (turbostat samples once every 5s), and then drops down.
AFAIK the most legible way to your PL settings:
# powercap-info -p intel-rapl
enabled: 1
Zone 0
enabled: 1
max_energy_range_uj: 262143328850
energy_uj: 8034164002
Constraint 0
power_limit_uw: 200000000
time_window_us: 27983872
max_power_uw: 28000000
Constraint 1
power_limit_uw: 64000000
time_window_us: 2440
max_power_uw: 0
Constraint 2
power_limit_uw: 90000000
time_window_us: 0
max_power_uw: 0
Zone 0:0
enabled: 0
energy_uj: 5141981221
Constraint 0
power_limit_uw: 0
time_window_us: 976
Zone 0:1
enabled: 0
energy_uj: 7017071
Constraint 0
power_limit_uw: 0
time_window_us: 976
Anyway, if turbostat show’s you aren’t able to sustain 28W, then you should try to see if better ventilation helps or a repaste. Otherwise, you’re getting the most performance out of your laptop as is possible.
BTW, you may also want to look at turbostat's full output to see how your idle is (C10%). When my laptop isn’t doing anything, it’s at ~99.8% idle. This is a lot more important for idle power usage but still, if you’re not mostly at idle when you’re not doing anything, you’re probably giving up some performance/thermal headroom.
