I’m aware of the gap problem with the spacers, but mine are both a slightly different colour of silver than the main body (and each other), which makes them look even worse. Is this normal, or did I get a bad batch?
This might be an issue. I think I recall an early batch or in one of the reviews that someone had different colored spacers. I don’t have any issues with the coloring on mine and I haven’t noticed it in any of the pictures on the gap issue forms.
I would reach out to Support. hopefully they can get you some that are a better match. Best of luck!
Please contact the support team and share pictures with them. I don’t remember seeing this problem before.
