Hi All, hope you’re having a good day
I’ve found myself wanting to output to two different audio sources a few times before, in the past I normally find a software solution to this, atm thats helvum. But with my framework 13 I find that I try to use any of these solutions and my laptop is listed as only having one output. From what I can tell that output represents both the audio-jack and the speakers and plugging in a jack hijacks the speakers audio.
Is there anyway to alter this so that I can output from both? I know I could get a jack splitter and external speakers it would be much nicer if I could avoid making a whole physical setup for this. On that note could I buy another audio jack port and would that then act as a separate output?
