How so? One of the screws is a “pusher” screw that will kind of pop like it’s cross-threaded, but that’s by design. It gives the cover a little push, enough to open a gap.
Ah, its on purpose? Didn’t occur to me when I was unscrewing it. Great, then!
Yes, there are 5 screws, 4 captive (retained) screws and one “lifter” screw.
Step 3:
Bottom left from underneath to help lift the input panel presumably
Ha! Nice. I was going to take some time to “fix” this screw, but I’ll leave it for now.
The keyboard panel has magnets to hold it down so it stays in place even when unscrewed. So the pusher screw gives you a bit of access space to easily pull the panel off.
Did any of you get your preparing for payment notification just at the end of the month? Or was every framework sent just at the end of the month?
