In the review from LTT they mention the ability to disable charging the battery while plugged in. Does this include the ability to set charge limits? I currently have a Dell laptop that allows you to set the max battery charge anywhere between 50-100% which is a great feature to extend the longevity of the battery. They even have a desktop interface that makes changing battery settings quick and easy. I would love to see something similar on the framework laptop!
