@ImaxinarDM @CraigO @David_Mischel You can see BIOS 3.07 + Windows 10 and (11 Alpha) driver bundle - #91 by Duane_Johnson .
Oh yea, understood @junaruga. And thanks. I was piping up in case the company was gauging whether there was a problem in email comm.
sorry if Iâve missed this information somewhere else, but has anyone from FW commented on adding memory XMP support so we can use some tighter latency memory?
It is not forthcoming, it is an Intel restriction with Framework unable to support it
is there another post with some more details about the specifics of this? is it a restriction in this model of CPU specifically? or does supporting it require some compromises in some way that FW isnât willing to do? other laptops certainly have this ability so it canât be intel across the board or impossible.
Text is for filler, please reference the above quote
thanks for the link. iâll continue discussion there.
Does anybody else receive this error?
âfailed to read EFI variable: Error opening file /sys/firmware/efi/efivars/OsIndications-8be4df61-93ca-11d2-aa0d-00e098032b8c: No such file or directoryâ
If youâre using base distributions, chances are they do not automatically mount the efivars.
Try running this
mount -t efivarfs efivarfs /sys/firmware/efi/efivars
and then running whatever you want to do with the efivars.
If the mount works and you want to make the mount permanant (auto-mount at every boot) add this to the /etc/fstab:
efivarfs /sys/firmware/efi/efivars efivarfs defaults,nosuid,nodev,noexec 0 0
If mount didnât happened with former command probably the system is booted in MBR/Legacy mode, (create backup first and) try formatting the SSD to GPT/UEFI and install OS again. UEFI is pretty much standard now a days, most probably you might just not have efivars mounted.
Hi Animesh,
Thank you for the reply! It appears that it is already mounted. When I run the mount commandâŚ
mount: /sys/firmware/efi/efivars: efivarfs already mounted on /sys/firmware/efi/efivars
Any other suggestions?
Thanks again,
J
Iâm not so sure then, but if kernel and bios are at latest, all the supported efivars should be right there.
Where else would you suggest I go to troubleshoot? I figured this thread would be the best place.
My exact error âfailed to read EFI variable: Error opening file /sys/firmware/efi/efivars/OsIndications-8be4df61-93ca-11d2-aa0d-00e098032b8c: No such file or directoryâ
@warehows123 hey, I just got my framework yesterday, and I see the OsIndications file is not present in the efivars, but if I write to it creating a new one, the changes are actually reflected. That is, if i run https://github.com/Animeshz/scripts/blob/main/reboot-firmware, it does reboot into BIOS.
Hey Animesh, I tried running your script and it did successfully reboot into BIOS. I afterwards tried to update again using both fwupdmgr and using the software app, and no longer get the failed to read EFI variable error, however after what seems like a successful install and reboot, my firmware version still is sitting at 03.02, so it doesnât seem to be applying it.
Well, after using it yesterday afternoon, I closed the lid for a few hours, and now it appears to be bricked. Exact same issue as this guy posted in another threadâŚOctober 12, 2021 - YouTube
I may be using it incorrectly since Iâm not confident itâs completely irreversible damage yet, but at this point Iâm unable to do anything with it and temporarily itâs unusable. I canât access bios and no keys work, itâs in a restart loop with fan coming on loud.
I get the exact same results after physically removing the NVMe drive from the laptop. Restart loops with the fan noise loud.
update: Iâve been opening and closing the laptop for a few minutes with some pressure and it now booted back up normal!!! Now that Iâm in, I want to securely update bios. Any other things to check
3 posts were split to a new topic: Battery degradation
Any insight into CPU Flex Override setting?
Iâve got no real clue what the valid range is, nor specifically any idea what will increase battery savings.
Grateful for any insight; best I can tell is it should be between 35 and 48?
3.5 Ghz standard, 4.8Ghz max turbo?
Is that correct?
Mine is currently set to 30, and it still turbos to the same upper threshold.
I would like to make the processor run as low as the minimum speed for as long as possible before clocking up. Can this setting do that?
Windows 10 maximum battery mode does not do enough about keeping the CPU running slow on my batch 5.
