Blender snap causes system hang and GPU reset
Ubuntu 22.04.4 LTS
Which release version?
Ubuntu 22.04.4 LTS
Which kernel are you using?
6.5.0-1027-oem #28-Ubuntu SMP PREEMPT_DYNAMIC Thu Jul 25 13:32:46 UTC 2024
The one the preorder batches shipped with (I forget the number)
Which Framework Laptop 16 model are you using? (AMD Ryzen™ 7040 Series)
7840HS + RX 7700S
Running Blender after installing it as a snap (version 4.2.1) causes the system to hang for an extended period and spin up the fans before it eventually recovers. After recovering, the system fans remain at a higher speed until reboot.
The very first time I opened Blender after installing, it ran without issue. All the subsequent attempts (two or three so far) have hung the system. I’m not using any environment variables to bias Blender towards using the integrated or discrete GPU, and I didn’t make any settings changes inside Blender during the first successful run.
Relevant section of dmesg pasted below. (Note: you’ll see several alt-sysrq help messages, which I thought were supposed to be logged when you use alt-sysrq-H; I was using S, U, and B. Maybe it’s disabled somehow?):
[  141.062457] [drm] PCIE GART of 512M enabled (table at 0x00000081FEB00000).
[  141.062488] [drm] PSP is resuming...
[  141.118739] [drm] reserve 0x1300000 from 0x81fc000000 for PSP TMR
[  141.210124] amdgpu 0000:03:00.0: amdgpu: RAS: optional ras ta ucode is not available
[  141.217585] amdgpu 0000:03:00.0: amdgpu: RAP: optional rap ta ucode is not available
[  141.217589] amdgpu 0000:03:00.0: amdgpu: SECUREDISPLAY: securedisplay ta ucode is not available
[  141.217594] amdgpu 0000:03:00.0: amdgpu: SMU is resuming...
[  141.217599] amdgpu 0000:03:00.0: amdgpu: smu driver if version = 0x00000035, smu fw if version = 0x0000003c, smu fw program = 0, smu fw version = 0x00524500 (82.69.0)
[  141.217605] amdgpu 0000:03:00.0: amdgpu: SMU driver if version not matched
[  141.254962] amdgpu 0000:03:00.0: amdgpu: SMU is resumed successfully!
[  141.256792] [drm] DMUB hardware initialized: version=0x07002800
[  142.999684] [drm] kiq ring mec 3 pipe 1 q 0
[  143.004492] [drm] VCN decode and encode initialized successfully(under DPG Mode).
[  143.005321] amdgpu 0000:03:00.0: [drm:jpeg_v4_0_hw_init [amdgpu]] JPEG decode initialized successfully.
[  143.005895] amdgpu 0000:03:00.0: amdgpu: ring gfx_0.0.0 uses VM inv eng 0 on hub 0
[  143.005899] amdgpu 0000:03:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
[  143.005901] amdgpu 0000:03:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
[  143.005903] amdgpu 0000:03:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 6 on hub 0
[  143.005905] amdgpu 0000:03:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 7 on hub 0
[  143.005906] amdgpu 0000:03:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 8 on hub 0
[  143.005908] amdgpu 0000:03:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 9 on hub 0
[  143.005910] amdgpu 0000:03:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 10 on hub 0
[  143.005912] amdgpu 0000:03:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 11 on hub 0
[  143.005913] amdgpu 0000:03:00.0: amdgpu: ring sdma0 uses VM inv eng 12 on hub 0
[  143.005915] amdgpu 0000:03:00.0: amdgpu: ring sdma1 uses VM inv eng 13 on hub 0
[  143.005917] amdgpu 0000:03:00.0: amdgpu: ring vcn_unified_0 uses VM inv eng 0 on hub 8
[  143.005919] amdgpu 0000:03:00.0: amdgpu: ring jpeg_dec uses VM inv eng 1 on hub 8
[  143.005921] amdgpu 0000:03:00.0: amdgpu: ring mes_kiq_3.1.0 uses VM inv eng 14 on hub 0
[  143.008121] amdgpu 0000:03:00.0: [drm] Cannot find any crtc or sizes
[  143.008692] [drm] ring gfx_32779.1.1 was added
[  143.009125] [drm] ring compute_32779.2.2 was added
[  143.009564] [drm] ring sdma_32779.3.3 was added
[  143.009597] [drm] ring gfx_32779.1.1 ib test pass
[  143.009624] [drm] ring compute_32779.2.2 ib test pass
[  143.009726] [drm] ring sdma_32779.3.3 ib test pass
[  154.467712] gmc_v11_0_process_interrupt: 1 callbacks suppressed
[  154.467718] amdgpu 0000:03:00.0: amdgpu: [gfxhub] page fault (src_id:0 ring:24 vmid:4 pasid:32777, for process blender pid 5400 thread blender:cs0 pid 5429)
[  154.467728] amdgpu 0000:03:00.0: amdgpu:   in page starting at address 0x000080003f800000 from client 10
[  154.467734] amdgpu 0000:03:00.0: amdgpu: GCVM_L2_PROTECTION_FAULT_STATUS:0x00401430
[  154.467737] amdgpu 0000:03:00.0: amdgpu: 	 Faulty UTCL2 client ID: SQC (data) (0xa)
[  154.467741] amdgpu 0000:03:00.0: amdgpu: 	 MORE_FAULTS: 0x0
[  154.467744] amdgpu 0000:03:00.0: amdgpu: 	 WALKER_ERROR: 0x0
[  154.467747] amdgpu 0000:03:00.0: amdgpu: 	 PERMISSION_FAULTS: 0x3
[  154.467750] amdgpu 0000:03:00.0: amdgpu: 	 MAPPING_ERROR: 0x0
[  154.467752] amdgpu 0000:03:00.0: amdgpu: 	 RW: 0x0
[  176.593808] sysrq: HELP : loglevel(0-9) reboot(b) crash(c) terminate-all-tasks(e) memory-full-oom-kill(f) kill-all-tasks(i) thaw-filesystems(j) sak(k) show-backtrace-all-active-cpus(l) show-memory-usage(m) nice-all-RT-tasks(n) poweroff(o) show-registers(p) show-all-timers(q) unraw(r) sync(s) show-task-states(t) unmount(u) force-fb(v) show-blocked-tasks(w) dump-ftrace-buffer(z)
[  177.285254] sysrq: HELP : loglevel(0-9) reboot(b) crash(c) terminate-all-tasks(e) memory-full-oom-kill(f) kill-all-tasks(i) thaw-filesystems(j) sak(k) show-backtrace-all-active-cpus(l) show-memory-usage(m) nice-all-RT-tasks(n) poweroff(o) show-registers(p) show-all-timers(q) unraw(r) sync(s) show-task-states(t) unmount(u) force-fb(v) show-blocked-tasks(w) dump-ftrace-buffer(z)
[  183.782681] sysrq: HELP : loglevel(0-9) reboot(b) crash(c) terminate-all-tasks(e) memory-full-oom-kill(f) kill-all-tasks(i) thaw-filesystems(j) sak(k) show-backtrace-all-active-cpus(l) show-memory-usage(m) nice-all-RT-tasks(n) poweroff(o) show-registers(p) show-all-timers(q) unraw(r) sync(s) show-task-states(t) unmount(u) force-fb(v) show-blocked-tasks(w) dump-ftrace-buffer(z)
[  184.061833] sysrq: HELP : loglevel(0-9) reboot(b) crash(c) terminate-all-tasks(e) memory-full-oom-kill(f) kill-all-tasks(i) thaw-filesystems(j) sak(k) show-backtrace-all-active-cpus(l) show-memory-usage(m) nice-all-RT-tasks(n) poweroff(o) show-registers(p) show-all-timers(q) unraw(r) sync(s) show-task-states(t) unmount(u) force-fb(v) show-blocked-tasks(w) dump-ftrace-buffer(z)
[  184.290675] sysrq: HELP : loglevel(0-9) reboot(b) crash(c) terminate-all-tasks(e) memory-full-oom-kill(f) kill-all-tasks(i) thaw-filesystems(j) sak(k) show-backtrace-all-active-cpus(l) show-memory-usage(m) nice-all-RT-tasks(n) poweroff(o) show-registers(p) show-all-timers(q) unraw(r) sync(s) show-task-states(t) unmount(u) force-fb(v) show-blocked-tasks(w) dump-ftrace-buffer(z)
[  184.505092] sysrq: HELP : loglevel(0-9) reboot(b) crash(c) terminate-all-tasks(e) memory-full-oom-kill(f) kill-all-tasks(i) thaw-filesystems(j) sak(k) show-backtrace-all-active-cpus(l) show-memory-usage(m) nice-all-RT-tasks(n) poweroff(o) show-registers(p) show-all-timers(q) unraw(r) sync(s) show-task-states(t) unmount(u) force-fb(v) show-blocked-tasks(w) dump-ftrace-buffer(z)
[  184.732360] sysrq: HELP : loglevel(0-9) reboot(b) crash(c) terminate-all-tasks(e) memory-full-oom-kill(f) kill-all-tasks(i) thaw-filesystems(j) sak(k) show-backtrace-all-active-cpus(l) show-memory-usage(m) nice-all-RT-tasks(n) poweroff(o) show-registers(p) show-all-timers(q) unraw(r) sync(s) show-task-states(t) unmount(u) force-fb(v) show-blocked-tasks(w) dump-ftrace-buffer(z)
[  184.971200] sysrq: HELP : loglevel(0-9) reboot(b) crash(c) terminate-all-tasks(e) memory-full-oom-kill(f) kill-all-tasks(i) thaw-filesystems(j) sak(k) show-backtrace-all-active-cpus(l) show-memory-usage(m) nice-all-RT-tasks(n) poweroff(o) show-registers(p) show-all-timers(q) unraw(r) sync(s) show-task-states(t) unmount(u) force-fb(v) show-blocked-tasks(w) dump-ftrace-buffer(z)
[  185.184719] sysrq: HELP : loglevel(0-9) reboot(b) crash(c) terminate-all-tasks(e) memory-full-oom-kill(f) kill-all-tasks(i) thaw-filesystems(j) sak(k) show-backtrace-all-active-cpus(l) show-memory-usage(m) nice-all-RT-tasks(n) poweroff(o) show-registers(p) show-all-timers(q) unraw(r) sync(s) show-task-states(t) unmount(u) force-fb(v) show-blocked-tasks(w) dump-ftrace-buffer(z)
[  185.423749] sysrq: HELP : loglevel(0-9) reboot(b) crash(c) terminate-all-tasks(e) memory-full-oom-kill(f) kill-all-tasks(i) thaw-filesystems(j) sak(k) show-backtrace-all-active-cpus(l) show-memory-usage(m) nice-all-RT-tasks(n) poweroff(o) show-registers(p) show-all-timers(q) unraw(r) sync(s) show-task-states(t) unmount(u) force-fb(v) show-blocked-tasks(w) dump-ftrace-buffer(z)
[  185.653686] sysrq: HELP : loglevel(0-9) reboot(b) crash(c) terminate-all-tasks(e) memory-full-oom-kill(f) kill-all-tasks(i) thaw-filesystems(j) sak(k) show-backtrace-all-active-cpus(l) show-memory-usage(m) nice-all-RT-tasks(n) poweroff(o) show-registers(p) show-all-timers(q) unraw(r) sync(s) show-task-states(t) unmount(u) force-fb(v) show-blocked-tasks(w) dump-ftrace-buffer(z)
[  186.385730] sysrq: HELP : loglevel(0-9) reboot(b) crash(c) terminate-all-tasks(e) memory-full-oom-kill(f) kill-all-tasks(i) thaw-filesystems(j) sak(k) show-backtrace-all-active-cpus(l) show-memory-usage(m) nice-all-RT-tasks(n) poweroff(o) show-registers(p) show-all-timers(q) unraw(r) sync(s) show-task-states(t) unmount(u) force-fb(v) show-blocked-tasks(w) dump-ftrace-buffer(z)
[  191.013868] sysrq: HELP : loglevel(0-9) reboot(b) crash(c) terminate-all-tasks(e) memory-full-oom-kill(f) kill-all-tasks(i) thaw-filesystems(j) sak(k) show-backtrace-all-active-cpus(l) show-memory-usage(m) nice-all-RT-tasks(n) poweroff(o) show-registers(p) show-all-timers(q) unraw(r) sync(s) show-task-states(t) unmount(u) force-fb(v) show-blocked-tasks(w) dump-ftrace-buffer(z)
[  192.296829] sysrq: HELP : loglevel(0-9) reboot(b) crash(c) terminate-all-tasks(e) memory-full-oom-kill(f) kill-all-tasks(i) thaw-filesystems(j) sak(k) show-backtrace-all-active-cpus(l) show-memory-usage(m) nice-all-RT-tasks(n) poweroff(o) show-registers(p) show-all-timers(q) unraw(r) sync(s) show-task-states(t) unmount(u) force-fb(v) show-blocked-tasks(w) dump-ftrace-buffer(z)
[  192.545673] sysrq: HELP : loglevel(0-9) reboot(b) crash(c) terminate-all-tasks(e) memory-full-oom-kill(f) kill-all-tasks(i) thaw-filesystems(j) sak(k) show-backtrace-all-active-cpus(l) show-memory-usage(m) nice-all-RT-tasks(n) poweroff(o) show-registers(p) show-all-timers(q) unraw(r) sync(s) show-task-states(t) unmount(u) force-fb(v) show-blocked-tasks(w) dump-ftrace-buffer(z)
[  204.838992] sysrq: HELP : loglevel(0-9) reboot(b) crash(c) terminate-all-tasks(e) memory-full-oom-kill(f) kill-all-tasks(i) thaw-filesystems(j) sak(k) show-backtrace-all-active-cpus(l) show-memory-usage(m) nice-all-RT-tasks(n) poweroff(o) show-registers(p) show-all-timers(q) unraw(r) sync(s) show-task-states(t) unmount(u) force-fb(v) show-blocked-tasks(w) dump-ftrace-buffer(z)
[  205.820254] sysrq: HELP : loglevel(0-9) reboot(b) crash(c) terminate-all-tasks(e) memory-full-oom-kill(f) kill-all-tasks(i) thaw-filesystems(j) sak(k) show-backtrace-all-active-cpus(l) show-memory-usage(m) nice-all-RT-tasks(n) poweroff(o) show-registers(p) show-all-timers(q) unraw(r) sync(s) show-task-states(t) unmount(u) force-fb(v) show-blocked-tasks(w) dump-ftrace-buffer(z)
[  206.018486] sysrq: HELP : loglevel(0-9) reboot(b) crash(c) terminate-all-tasks(e) memory-full-oom-kill(f) kill-all-tasks(i) thaw-filesystems(j) sak(k) show-backtrace-all-active-cpus(l) show-memory-usage(m) nice-all-RT-tasks(n) poweroff(o) show-registers(p) show-all-timers(q) unraw(r) sync(s) show-task-states(t) unmount(u) force-fb(v) show-blocked-tasks(w) dump-ftrace-buffer(z)
[  206.237997] sysrq: HELP : loglevel(0-9) reboot(b) crash(c) terminate-all-tasks(e) memory-full-oom-kill(f) kill-all-tasks(i) thaw-filesystems(j) sak(k) show-backtrace-all-active-cpus(l) show-memory-usage(m) nice-all-RT-tasks(n) poweroff(o) show-registers(p) show-all-timers(q) unraw(r) sync(s) show-task-states(t) unmount(u) force-fb(v) show-blocked-tasks(w) dump-ftrace-buffer(z)
[  216.103788] [drm:amdgpu_job_timedout [amdgpu]] *ERROR* ring comp_1.2.0 timeout, signaled seq=10, emitted seq=11
[  216.104414] [drm:amdgpu_job_timedout [amdgpu]] *ERROR* Process information: process blender pid 5400 thread blender:cs0 pid 5429
[  216.104919] amdgpu 0000:03:00.0: amdgpu: GPU reset begin!
[  217.127737] amdgpu 0000:03:00.0: amdgpu: IP block:gfx_v11_0 is hung!
[  217.128432] amdgpu 0000:03:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0010 address=0xe3c77200 flags=0x0020]
[  217.128462] amdgpu 0000:03:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0010 address=0xe3c77288 flags=0x0020]
[  217.128484] amdgpu 0000:03:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0010 address=0xe3c77200 flags=0x0020]
[  217.128503] amdgpu 0000:03:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0010 address=0xe3c77234 flags=0x0020]
[  217.128522] amdgpu 0000:03:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0010 address=0xe3c77244 flags=0x0020]
[  217.128542] amdgpu 0000:03:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0010 address=0xe3c77274 flags=0x0020]
[  217.128560] amdgpu 0000:03:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0010 address=0xe3c77284 flags=0x0020]
[  217.128579] amdgpu 0000:03:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0010 address=0xe3c772a4 flags=0x0020]
[  217.128598] amdgpu 0000:03:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0010 address=0xe3c772c4 flags=0x0020]
[  217.128617] amdgpu 0000:03:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0010 address=0xe3c772d0 flags=0x0020]
[  217.128837] [drm] kiq ring mec 3 pipe 1 q 0
[  217.135990] amdgpu 0000:03:00.0: amdgpu: recover vram bo from shadow start
[  217.136531] amdgpu 0000:03:00.0: amdgpu: recover vram bo from shadow done
[  217.266185] [drm:mes_v11_0_submit_pkt_and_poll_completion.constprop.0 [amdgpu]] *ERROR* MES failed to response msg=14
[  217.266362] [drm:amdgpu_mes_reg_write_reg_wait [amdgpu]] *ERROR* failed to reg_write_reg_wait
[  217.400041] [drm:mes_v11_0_submit_pkt_and_poll_completion.constprop.0 [amdgpu]] *ERROR* MES failed to response msg=14
[  217.400244] [drm:amdgpu_mes_reg_write_reg_wait [amdgpu]] *ERROR* failed to reg_write_reg_wait
[  217.531502] [drm:mes_v11_0_submit_pkt_and_poll_completion.constprop.0 [amdgpu]] *ERROR* MES failed to response msg=14
[  217.531823] [drm:amdgpu_mes_reg_write_reg_wait [amdgpu]] *ERROR* failed to reg_write_reg_wait
[  217.665197] [drm:mes_v11_0_submit_pkt_and_poll_completion.constprop.0 [amdgpu]] *ERROR* MES failed to response msg=14
[  217.665385] [drm:amdgpu_mes_reg_write_reg_wait [amdgpu]] *ERROR* failed to reg_write_reg_wait
[  217.799278] [drm:mes_v11_0_submit_pkt_and_poll_completion.constprop.0 [amdgpu]] *ERROR* MES failed to response msg=14
[  217.799540] [drm:amdgpu_mes_reg_write_reg_wait [amdgpu]] *ERROR* failed to reg_write_reg_wait
[  217.933265] [drm:mes_v11_0_submit_pkt_and_poll_completion.constprop.0 [amdgpu]] *ERROR* MES failed to response msg=14
[  217.933458] [drm:amdgpu_mes_reg_write_reg_wait [amdgpu]] *ERROR* failed to reg_write_reg_wait
[  218.067166] [drm:mes_v11_0_submit_pkt_and_poll_completion.constprop.0 [amdgpu]] *ERROR* MES failed to response msg=14
[  218.067357] [drm:amdgpu_mes_reg_write_reg_wait [amdgpu]] *ERROR* failed to reg_write_reg_wait
[  218.198496] [drm:mes_v11_0_submit_pkt_and_poll_completion.constprop.0 [amdgpu]] *ERROR* MES failed to response msg=14
[  218.198647] [drm:amdgpu_mes_reg_write_reg_wait [amdgpu]] *ERROR* failed to reg_write_reg_wait
[  218.330664] [drm:mes_v11_0_submit_pkt_and_poll_completion.constprop.0 [amdgpu]] *ERROR* MES failed to response msg=2
[  218.330941] [drm:amdgpu_mes_add_hw_queue [amdgpu]] *ERROR* failed to add hardware queue to MES, doorbell=0x1000
[  218.331177] [drm:amdgpu_mes_self_test [amdgpu]] *ERROR* failed to add ring
[  218.465641] [drm:mes_v11_0_submit_pkt_and_poll_completion.constprop.0 [amdgpu]] *ERROR* MES failed to response msg=14
[  218.465856] [drm:amdgpu_mes_reg_write_reg_wait [amdgpu]] *ERROR* failed to reg_write_reg_wait
[  218.599555] [drm:mes_v11_0_submit_pkt_and_poll_completion.constprop.0 [amdgpu]] *ERROR* MES failed to response msg=14
[  218.599774] [drm:amdgpu_mes_reg_write_reg_wait [amdgpu]] *ERROR* failed to reg_write_reg_wait
[  218.732372] [drm:mes_v11_0_submit_pkt_and_poll_completion.constprop.0 [amdgpu]] *ERROR* MES failed to response msg=14
[  218.732596] [drm:amdgpu_mes_reg_write_reg_wait [amdgpu]] *ERROR* failed to reg_write_reg_wait
[  218.862583] [drm:mes_v11_0_submit_pkt_and_poll_completion.constprop.0 [amdgpu]] *ERROR* MES failed to response msg=14
[  218.862775] [drm:amdgpu_mes_reg_write_reg_wait [amdgpu]] *ERROR* failed to reg_write_reg_wait
[  218.992828] [drm:mes_v11_0_submit_pkt_and_poll_completion.constprop.0 [amdgpu]] *ERROR* MES failed to response msg=2
[  218.993082] [drm:amdgpu_mes_add_hw_queue [amdgpu]] *ERROR* failed to add hardware queue to MES, doorbell=0x1000
[  218.993329] [drm:amdgpu_mes_self_test [amdgpu]] *ERROR* failed to add ring
[  219.127075] [drm:mes_v11_0_submit_pkt_and_poll_completion.constprop.0 [amdgpu]] *ERROR* MES failed to response msg=14
[  219.127258] [drm:amdgpu_mes_reg_write_reg_wait [amdgpu]] *ERROR* failed to reg_write_reg_wait
[  219.260975] [drm:mes_v11_0_submit_pkt_and_poll_completion.constprop.0 [amdgpu]] *ERROR* MES failed to response msg=14
[  219.261155] [drm:amdgpu_mes_reg_write_reg_wait [amdgpu]] *ERROR* failed to reg_write_reg_wait
[  219.394527] [drm:mes_v11_0_submit_pkt_and_poll_completion.constprop.0 [amdgpu]] *ERROR* MES failed to response msg=14
[  219.394795] [drm:amdgpu_mes_reg_write_reg_wait [amdgpu]] *ERROR* failed to reg_write_reg_wait
[  219.528928] [drm:mes_v11_0_submit_pkt_and_poll_completion.constprop.0 [amdgpu]] *ERROR* MES failed to response msg=14
[  219.529127] [drm:amdgpu_mes_reg_write_reg_wait [amdgpu]] *ERROR* failed to reg_write_reg_wait
[  219.662388] [drm:mes_v11_0_submit_pkt_and_poll_completion.constprop.0 [amdgpu]] *ERROR* MES failed to response msg=2
[  219.662645] [drm:amdgpu_mes_add_hw_queue [amdgpu]] *ERROR* failed to add hardware queue to MES, doorbell=0x1200
[  219.662855] [drm:amdgpu_mes_self_test [amdgpu]] *ERROR* failed to add ring
[  219.664203] amdgpu 0000:03:00.0: amdgpu: GPU reset(1) succeeded!
