I love that the new screen for the Framework 13 was make to be backwards compatible and fit into all generations of the FW13, it’s really impressive to have 4 generations with that much compatibility.
Eventually it seems like there will need to be breaking changes, for example if the FW13 wanted to support a keyboard module similar to the one in the FW16.
Has there been any thought about when a breaking change will happen? What support will look like for older versions? How to build a compatibility checker to ensure you don’t by a part that doesn’t work with your version etc?
Similarly, and obviously we can’t hold anyone to specifics in this thread, is there any though about what kinda of change would be impactful enough to warrant a breaking change? For example, if LPCAMM2 changed the mainboard enough to require a breaking change would that be worth it?
I know this is a classic trap, but I feel like there is some cool tech right around the corner and it always makes me hesitant to buy something right now, I always agonize over if I should wait just a touch longer…
