Can I improve upon 10 hours of battery on 13 Pro (Limited Batch)?
I’ve had my 13 pro for a few days now. I have the limited batch version. I’m using Artix linux and am running a power management daemon on KDE plasma. Doing basic web browsing, my estimates are around 9-10 hours of battery. Doing the same thing on my wife’s 13 inch m1 (the OG) macbook pro registers nearly 17 hours.
I wasn’t expecting a miracle but I was expecting more if I’m honest. I was hoping for 14 hours or more of moderate use. I describe moderate use as browsing the web, using text editors, things like that. Not rendering video or compiling massive code projects.
I’m curious if I’m doing something wrong? The sleep and idle times are incredible. So when doing literally nothing, it does have great battery life. It’s just that the second you do ANYTHING, no matter how small, that drops like a rock.
Any help would be appreciated.
Could we see some uptime load average and powertop readings? Maybe there are some consumption savings to be made.
Have you tested using one of the supported distros in a live environment? That and what @Squiggler said would be helpful. Since FW would point you towards a supported distro anyways…
Also, just a thought—I want to do this as well—if you don’t use the touch-screen, it might save some power to disable it.
Actually I don’t use it, that’s a good call. Also, I’ve been investigating and I think it fluctuates wildly because it depends when it takes the reading. If you catch it taking a power estimation at just the right time, opening Claude tab in a browser or something, it estimates pretty low. I think that’s why it’s showing so low for me.
I have read about some issues under some distros, specifically ones running tuned-ppd causing it to drain faster than it should. Also there are some reports of USB-A ports causing odd power draw with nothing plugged in, though I believe that is linked to older framework USB-A ports and not the newer black modules that ship with the Pro.
I am using Ubuntu 26.04 and have been pretty satisfied with the batter life. Usually in the 14 or so hour range with my normal tasks.
Another idea; consider changing the screen from a 120Hz refresh rate down to 60. I think that would save some power, and I should think the lower rate would still be very good.
My guess is always hardware acceleration issues:
  • Check browser’s hardware acceleration; is video hardware decoded?
  • The other apps you are using - are they electron based wrappers? If so, check if they are hardware decoding. Any animation these days is a video.
    • Containerized apps (e.g. Flatpak) tends more to have trouble utilizing hardware acceleration.
I don’t think you can get 17 but getting 12 hours should be quite easy. I regularly get 8+ hours of web browsing on the X7 board w/ old chassis & 51wh battery.
Thank you for all the great suggestions! I really appreciate the responses :slight_smile:
Let us know what kinds of battery performance you get - it will be interesting to see how much you can push it.
After making some of the adjustments stated in here, I’m at 75% battery with an estimated 9-10 hours of reaming battery doing those same tasks I mentioned. Obviously, more aggressive tasks drop that, but that is expected. I am satisfied with the results. The changes I had to make are not noticeable to me based on what I’m doing with the laptop. I don’t even use the touchscreen, and I mostly do casual web browsing and open source software development, which is mainly typing in a text editor.
I think I can probably get the 14 hours I was expecting now, so I really do appreciate all the suggestions.
Ok I have come back with more information this time. I have discovered that kwin_wayland and plasmashell seem to be using a lot of CPU when they should be doing next to nothing. After some digging it appears the selective refresh of PSR2 (panel self refresh) is failing, which means my compositor is doing full frame refreshes.
Does anyone know if this is a kernel issue with the most recent panther lake CPUs? Is this just me?
[ 4.968161] xe 0000:00:02.0: [drm] Selective fetch area calculation failed in pipe A
EDIT: I noticed there was an extremely recent patch put in for this, so I updated from 7.1.9 to 7.2.2 kernel and it appears to have resolved the high cpu load and selective refresh. My battery life has gone up again!
I will say, I’m not sure how Ubuntu is going to deal with this not being on the latest kernel. All while claiming the device is “fully supported”.
Ok I have an update. The kernel update appeared to fix it because I restarted my machine after updating. I noticed the problem return. After hours and hours of testing, it turns out it is a plasmashell issue.
What happens. When I close my laptop lid and the laptop suspends, something about waking up doesn’t recover well in plasmashell. Restarting plasmashell or restarting my computer resolves the issue. It is 100% reproducible. I have tried not using an image wallpaper and instead use a color. I’ve tried removing fractional scaling, I’ve tried using GUI painting to see what’s going on and you can see it refreshing 120 times a second after waking, but on a fresh plasmashell it doesn’t refresh at all unless it needs to.
I’m not sure where to go from here. I think I’m going to write up an issue to the plasma team. This is a measurable power drain difference on the battery. It’s possible this bug was introduced in a newer kernel if it’s not present on Ubuntu.
When restarting plasmashell on opening my laptop lid and unlocking the difference is around 4 hours of battery life compared to if I don’t.
EDIT: I have reported this to the KDE team. Bug report
If anyone else runs into this issue. I have created an autorun script that can resolve it for you. First run this command.
mkdir -p ~/.local/bin && cat > ~/.local/bin/plasma-resume-fix.sh << 'EOF'
#!/bin/sh
# Workaround: restart plasmashell after resume to stop the repaint loop.
# Remove this file and ~/.config/autostart/plasma-resume-fix.desktop once KDE fixes the bug.
# Stop any copies left over from earlier logins so only one runs.
for pid in $(pgrep -f "^/bin/sh .*plasma-resume-fix"); do
  [ "$pid" != "$$" ] && kill "$pid" 2>/dev/null
done
pkill -f "gdbus monitor --system --dest org.freedesktop.login1" 2>/dev/null
last=0
stdbuf -oL gdbus monitor --system --dest org.freedesktop.login1 --object-path /org/freedesktop/login1 |
while read -r line; do
  case "$line" in
    *"PrepareForSleep (false"*)
      now=$(date +%s)
      # Ignore repeat wake signals within 30 seconds of the last restart.
      [ $((now - last)) -lt 30 ] && continue
      last=$now
      sleep 5
      kquitapp6 plasmashell
      kstart plasmashell
  esac
done
EOF
chmod +x ~/.local/bin/plasma-resume-fix.sh
Then run this command.
mkdir -p ~/.config/autostart && cat > ~/.config/autostart/plasma-resume-fix.desktop << EOF
[Desktop Entry]
Type=Application
Name=Plasma resume fix
Exec=$HOME/.local/bin/plasma-resume-fix.sh
EOF
Then logout and back in. When you resume from suspend this will automatically restart plasmashell for you. Once the bug is fixed you can remove it with this command.
rm ~/.local/bin/plasma-resume-fix.sh ~/.config/autostart/plasma-resume-fix.desktop
Logout and back in.
By swapping to the 2.2k screen.
I’m not joking, ever since I swapped my 2.2k on my 7040U series FL13 to the 2.8k, the battery runtime went from 6-8(due to 83% of battery health) to 4-5 hours even if I lower the brightness to lower than normal usage on the previous screen.
If some reviewers can do 17 hours, swapping to 2.2k may get you to 24 hours or longer
definitely worth testing once i can get a chassis kit with the new display
Wanted to add my small finding:
switching screen from 120HZ+accurate colors to 60Hz+efficient coloring drops idle and media play power consumption by ~40%.
But did you check accurate colors @ 60hz? Seems to me that the drop in refresh rate would be responsible for most if not all of that.
If you use VRR make sure it’s set to “automatic” rather than “always”. “Always” will set the refresh rate of the GPU output to the screen at idle, displacing panel self-refresh (PSR), causing an increase energy consumption on at idle. When playing media, use full screen to fully take advantage of VRR since PSR is inactive due to moving scene.
I tried both VRR always and automatic didn’t help.
And I also measured that color efficiency actually give similar benefit as lowering refresh rate.
