Can medium input modules mount on the left side?
Hi, I can only find examples of the medium input modules like the numpad being mounted on the right side of the laptop. Does anybody know if they can be mounted on the left side?
Thanks,
James
Yes. You can have keyboard right, center or left. Trackpad can also follow same. Numpad can be either side. Take a few minutes and watch this new video introducing the Laptop 16. It should answer all your questions.
https://youtu.be/L9Ww_7wwNkM
Thank you Scott_H!
