This has been mentioned in another topic about the new Ultra 13" and does make sense.
Panel fragmentation vs bezel fragmentation. The panel provides a functional improvement, whereas bezel wouldnāt. I guess.
It would provide the benefit of making me happy Perhaps other customers too. I know Iām just one customer, but I think it would go a long way to making the fit and finish closer to that of other manufacturers.
Having a rectangular bezel that lets you see the rounded display is very obvious and looks pretty bad. Framework could keep 99% of the bezel the same, just a different mould.
Hi and welcome.
This has been discussed. The main issue would seem to be that the screen is only a temp solution and one without rounded corners should be around the corner and even if not soon: the creation of a new mold would cost a bit ?? and then how many bezels to make ?? ~ for what may be a temp use of a rounded corner screen.
If it is really an eyesore Iām sure a user can modify the bezel by adding bits.
See other posts etc.
