Charge levels configurable from KDE userspace
So it seems to work. Discharge stopped at 79% (set 80%)
State is still “discharging”, but I suppose that’s because there isn’t a battery bypass circuit?
And for posterity, the charge limit set in BIOS being ignored is tracked in github.
So it didn’t stop discharging, just sloooowed down. I’m now down to 70%.
It seems setting min and max to the same number might cause it to never start charging.
This part of the fw is really buggy :worried:
Oh you are right. That is unfortunate. The older framework_laptop module I posted above and was using until recently did not have this limitation.
I’ll do more testing on my side, but it does appear once ectool is used, the charge_control_end_threshold and start sysfs locations stop working. I have bios set to 100% but I can see this being very annoying to any users who set their bios to <100%. Hopefully something that will get fixed in a future kernel.
So just to recap for myself. This framework-laptop-kmod is not needed anymore with kernel 6.14 and up right?
Is there something else that is good to know. Just making sure before we remove this module from our uBlue images
kmod isn’t required, but probe_with_fwk_charge_control is.
For newer BIOS/firmware releases (3.09 on the 7040 and 3.03 on the 300 series), this is also required: mfd: cros_ec: Separate charge-control probing from USB-PD
So, on my Framework 13 with an Intel Core Ultra 5 125H and BIOS 3.05 running Arch Linux and kernel 6.15.9, I tried adding the probe_with_fwk_charge_control option for the cros_charge_control module, which did nothing, so I tried patching the kernel with the “Separate charge-control probling from USB-PD” patch, and now I see both the sysfs charge control files and the GUI option to set charge limits in KDE, however if I set the charge thresholds to 75% lower and 80% upper, the laptop charges the battery straight past 80% as if I never set any limit at all. That is even with the BIOS battery charge limit set to 100% and the BIOS battery extender disabled.
In the end the only ways I can get some kind of charge limit to actually stick as it stands is either through the BIOS charge limit setting or using framework_tool to set the charge limit. Is there anything else I’m missing to get the sysfs/GUI stuff to work?
Edit: Just found the framework_tool –console follow command to check the EC logs, so I had that running, changed the battery charge limit in the GUI and this is what I see:
[1051.484400 Sustainer enabled: 75 ~ 79%]
+[1051.489200 Sustainer updated: 75 ~ 80% (from 75 ~ 79%)]
[1052.472600 Sustainer disabled]
So is that a bug in the BIOS/EC code or what?
Seems so:
Thanks, that helped me a lot!
