Charge limit wont reset
I’d previously set a charge limit (of 60%) in the BIOS. Today, I reset the limit to 100%. However, when I plug in a charger, it reaches 60%, stops charging and continues to discharge (presumably until empty). I have to physically disconnect/reconnect the charger for it to resume charging, but it still only ever reaches 60% and starts discharging.
The laptop’s currently plugged in at 44%. The OS reports it as discharging and the LED is solid white. This occurs no matter which port/side I put the charger in.
❯ cat /sys/class/power_supply/BAT1/status
Discharging
❯ cat /sys/class/power_supply/BAT1/capacity
44
❯ sudo ectool fwchargelimit
100
I’ve not experienced this behaviour before - only after today when I reset the charge limit.
  • Linux v6.11.0
  • BIOS: 03.05
  • Framework 13 AMD 7640U
Watching ectool console:
It charges steadily to ~61%:
[721447.636700 Battery 58% (Display 57.9 %) / 2h:39 to full]
[721460.657300 Battery 58% (Display 58.0 %) / 2h:38 to full]
[721472.676200 Battery 58% (Display 58.1 %) / 2h:39 to full]
[721767.839800 Battery 61% (Display 60.9 %) / 2h:22 to full]
Then switches to discharge, orange LED changed to white:
[721778.853400 sustain_battery_soc: Switched control mode to DISCHARGE]
[721778.859200 Battery 61% (Display 61.0 %) / 2h:23 to full]
This repeats a few times, then floods of charge_request:
[722049.520700 charge_request(15696mV, 0mA)]
[722049.770900 charge_request(15664mV, 0mA)]
[722050.014000 charge_request(15760mV, 0mA)]
Interestingly, it continues to report 61%:
[722050.256700 Battery 61% (Display 60.2 %) / 5h:25 to empty]
[722050.504400 charge_request(15792mV, 0mA)]
… but doesn’t match the OS:
58
Discharging
This is an issue with the charge sensor inside the battery. The coulomb counter starts to assume that 60% is the maximum charge that the battery can hold which is why it stops charging at 60%.
To fix this, discharge your batter completely or to a low level like 10%. Then plug in the charger and let it charge fully. You may have to do this more than once.
Thank you. I’ve read about this before. Will try it and report back.
I’ve just done this (to ~2% when the OS issued a shutdown), but the issue persists.
