CPU Fan not spinning up until I reboot
I’ve been experiencing an occasional issue where the CPU fan doesn’t spin up until I reboot. When I run the sensors command, the cros_ec-isa-0000 section lists cpu@4c as FAULT and the fan1 speed as 0 RPM.
Rebooting always fixes the issue. I’m not sure how frequently this happens because the fan is usually pretty quiet. I haven’t contacted support because this feels like a Firmware bug.
Distro: Arch Linux w/ CachyOS Kernel (although I remember seeing this before on stock Arch Linux).
Kernel: 6.11 (but not new to this release).
Laptop: Framework AMD 13.
Can you give a more specific kernel version you’re on?
That’s strange. That is something I have never experienced in my Framework AMD 13. Perhaps BIOS update or looking for kernel update. Could also be a hardware problem but mostly those problems have software solutions, as a first step.
I am on stock Arch Linux (but LTS kernel) and I’ve experienced this multiple times. I’ll be in a video conference for work and notice that my temperature reading in my status bar shows 99℃ and my fan isn’t spinning at all. Just like you, I’d reboot and then suddenly my fans would roar on at their highest speed because the laptop was literally hot enough to boil water.
Distro: Arch Linux
Kernel: 6.6 LTS (Can’t go more specific because I don’t remember which point release I was on the last time it happened. It was within the past month.)
Yeah it’s happened to me once too this week, thought I was going crazy. A reboot fixed it - I should have tried using ec-tool to see if manually setting the fan controller to 100% then auto would fix it but next time.
Kernel: 6.11.0 (but it happened before as well)
Bios: 03.05
If you run a load do you ever see a RPM reported? One person had erratic fan behavior and one of the fan connector pins was bent.
You could also check ectool to see what the temperature/fan settings are. Maybe something is out of wack, a sensor is reporting something weird or a sensor stops reporting.
The same problem Linux, kernel 6.11.1-arch1-1. Didn’t notice before, first time today. Works fine after reboot.
can’t use ec-tool due toot secure boot/lockdown kernel.
UPDATE. my bad, ec-tool works now as 6.11
Happened to me again today. Kernel version 6.6.54-1-lts on Arch Linux.
Happened to me again today, this time I used ectool and saw the same behavior described in the first post and my status bar listed my temperature as 180℃, and it would have burned me if I touched the bottom of my laptop for more than a split second. Dear framework, please fix your buggy firmware, I don’t think my laptop appreciates being baked from the inside out.
ectool pwmgetfanrpm:
Fan 0 RPM: 0
ectool temps all:
--sensor name -------- temperature -------- ratio (fan_off and fan_max) --
local_f75303@4d       307 K (= 34 C)           0% (313 K and 343 K)
cpu_f75303@4d         305 K (= 32 C)           0% (319 K and 327 K)
ddr_f75303@4d         306 K (= 33 C)        N/A (fan_off=401 K, fan_max=401 K)
Sensor 3 error
That “Sensor 3 error” is referring to “cpu@4c” which I can confirm by running the same command after a reboot.
I ran into what seems like the same thing today.
Distro: Debian sid
Kernel: 6.11.6-amd64
Laptop: Framework 13 AMD Ryzen 7 7840U (new mainboard upgraded from an 11th gen Intel)
Bios: 03.05
Near the end of a video call just now I noticed my laptop was extremely hot to the touch. sensors reported cpu@4c: FAULT, and ectool temps all reported Sensor 3 error.
I was able to turn on the fan with ectool fanduty 100. The fan immediately turned off upon ectool autofanctrl. Even after the temperature is back down, sensors and ectool temps all still report the fault status. I don’t see anything obvious in dmesg.
Suspending then immediately awakening seems to have reset it for me, after doing that sensors and ectool temps all report normal-seeming values.
Same issue here.
Distro: Debian sid
Kernel: 6.12.6-amd64
Bios: 03.05
ectool temps all
cpu_f75303@4d         309 K (= 36 C)           0% (319 K and 327 K)
ddr_f75303@4d         307 K (= 34 C)        N/A (fan_off=401 K, fan_max=401 K)
cpu@4c                325 K (= 52 C)           0% (376 K and 378 K)
No amount of rebooting helped and ectool autofanctrl just sets fan speed to 0. I have to resort to manually setting the fan speed after each boot.
I have discovered GitHub - TamtamHero/fw-fanctrl: A simple systemd service to better control Framework Laptop's fan(s) which at least allows the fans to automatically spin up based on load.
If the EC is detecting a problem reading a cpu@4c sensor, then one would need to understand which bits of hardware and software are responsible for that sensor value. We don’t have detailed enough schematics to answer this.
If the EC is responsible for the sensor and the fans then maybe it is a bug on the EC side or a near faulty sensor.
This is a little perplexing because rebooting the laptop does not necassarily reboot the EC so it is odd how rebooting fixed this.
What reboot procedure did people use? FYI, the EC is only reset if one powers off, removes the psu and wait 40 seconds before powering on again.
This does maybe highlight a failure mode that is not covered correctly by the EC. I would suggest that if one cannot read the temp sensor, fans should more safely be set at max, not off.
Same issue here, but it happened on my Windows partition. Noticed because I was compiling a project and curiously I had no fan noise. Checked hardware info and saw my CPU pinned at 100C.
Had this issue today on an AMD 13" running the pulled firmware 3.06 beta. Not sure if the firmware is related but I did notice in HWinfo that the CPU Skin Temperature was stuck around 31C while all other temps were in the 90s. A reboot immediately had the fan on full blast, and when I got into Windows, it was showing a proper CPU skin temperature of 50C.
One neat thing about Framework’s firmware bugs causing our laptops to try their hardest to self-immolate is we’ve served as a decent test run proving a silent (and therefore fanless) AMD FW13 is completely usable/reasonable. We just need it to thermal throttle somewhere below the pain threshold and optionally a different heat sink design.
:frowning: I was really hoping this firmware release would have fixed the issue considering the excellent sleuthing on the temp sensor issue in this thread ~3 months ago (especially the posts by Thomas_Weissschuh)
This happened to me on an AI 300 today. My laptop was getting hot and I noticed the fan wasn’t spinning. I started building a kernel and it started getting really hot. Still not fan. Killed the build, shut down, started again and the fan started going immediately.
kernel-6.17.8-300.fc43.x86_64 Latest firmware.
This has happened to me several more times. It seems like if I come off AC power and then plug it in and start doing something more intensive the laptop will then get hot without the fan coming on.
But, to compound the issues, my fan is definitely failing. It has made a faint rattling sound in the past, but last night it got very loud and even stopped spinning. After a restart it started up again. but I have ordered a replacement fan because I do not expect it to last.
I’ve lately had a similar over-heating issue on my Framework 13 11th Gen Intel with latest firmware and linux kernel version 6.18.3 #1-NixOS SMP PREEMPT_DYNAMIC using fw-fanctrl wiith a custom temperature curve.
The device starting overheating, the fan would not spin.
I closed all programs and put the device into sleep mode (using systemd hybrid-sleep) in order for it to cool down. After the temps went down I resumed and poked around, not being able to detect any of the fans.
Multiple sleeps (while reading the forum and finding this thread) & resumes later ectool was showing the fan as stalled. Blowing into the air-intake area of the fan unstuck it. It has been working reliably since than.
In hindsight I found the following errors in my system journal:
 Jan 23 17:12:31 aitutaki fw-fanctrl[1533556]: Sensor 4 error
 Jan 23 18:00:52 aitutaki fw-fanctrl[1558050]: Sensor 4 error
The second timestamp overlaps with the laptop heating up and me putting the system to sleep ~7min later. I don’t remember the laptop getting recognizably hot around the first log message.
I’m posting in hope another data-point might be helpful to understand this issue.
Greetings folks,
If you’re experiencing this (fan not spinning under load, especially after sleep or AC transitions), please contact Framework Support so we can take a closer look at your specific system.
When you reach out, include a link to this thread and note your laptop model, firmware version, kernel version, and whether a reboot restores fan behavior — that context helps us correlate reports and determine next steps.
