(in case a new chassis version ever comes out)
-360 degree hinge
-hotswap battery bay would be nice
-The scallop at the front of the chassis for opening the screen is far too shallow. Especially as the bezel and frame behind the display are not flush but staggered. There’s less than a millimeter between the edge of the bezel and the back of the scallop and my fingernail always slips off of it on the first try. And I’m afraid of scratching up the soft, rubbery plastic of the bezel with my fingernails.
-It seems to me that it would be rather easy to improve the audio quality by making the speakers upward firing. Just leave them where they are but mill holes in the top instead of the bottom and rotate them 180 degrees.
