This worked for me on a Lenovo Gen2 USB-C dock (Type: 40AS Model-NO: LDC-G2 Rev: A1)
Framework 13 AMD 7840u
Did you end up picking up one of these docks? If so, how is it working for you?
Hi, I haven’t bought one yet, the good ones are very expensive. Long term plan is to use eGPU, so looking for expandability and ethernet in the dock I get.
I’m also very fascinated by docks that only provide TB4 downstream, so possibly using Framework expansion modules downstream of the dock. Still some more investigation needed as these get very expensive.
